Kioti ck25 stuck in 3rd gear
/ Kioti ck25 stuck in 3rd gear #1
kpoke
Farmall bn
I've got a kioti ck25 tractor that is stuck in 3rd gear . Not exactly sure what's wrong but believe it's a bent fork in the transmission.
I had the tractor fixed for the same problem a few years ago ,but the tractor is not worth the repair price again . Has anyone ever fixed this without splitting the tractor? Thanks
/ Kioti ck25 stuck in 3rd gear #2
Hydrostatic or standard transmission? My Mitsubishi used to get stuck in second from time to time. It was a standard and I could remove the shift assembly from the top of the transmission. I could then use a big screwdriver or pry bar to move the gear on its shaft, freeing it. I had this happen twice in fifteen years.
Manual transmission. There is a access plate that shift assembly goes through on the side of the transmission
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
