Kioti ck25 stuck in 3rd gear
/ Kioti ck25 stuck in 3rd gear #1
kpoke
Farmall bn
I've got a kioti ck25 tractor that is stuck in 3rd gear . Not exactly sure what's wrong but believe it's a bent fork in the transmission.
I had the tractor fixed for the same problem a few years ago ,but the tractor is not worth the repair price again . Has anyone ever fixed this without splitting the tractor? Thanks
/ Kioti ck25 stuck in 3rd gear #2
Hydrostatic or standard transmission? My Mitsubishi used to get stuck in second from time to time. It was a standard and I could remove the shift assembly from the top of the transmission. I could then use a big screwdriver or pry bar to move the gear on its shaft, freeing it. I had this happen twice in fifteen years.
Manual transmission. There is a access plate that shift assembly goes through on the side of the transmission
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A  SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
Wacker Neuson EZ26 (A60462)
Wacker Neuson EZ26...
