Kioti ck25 4/4 not working
   / Kioti ck25 4/4 not working #1
Leonard malone
Bronze Member
Kioti ck 25
The front axle is leaking fluid and the front wheel drive stopped working. If I continue to use tractor in 2 wheel drive will it do more damage to the front axle. Wondering if I could or should remove front drive shaft. Any thoughts would be appreciated. Thanks Len
   / Kioti ck25 4/4 not working #2
I'm not that knowledgeable on tractor front axle types, but I suspect most, if not all of the components are rotating whether the 4 wheel drive is engaged or not.
I would not use the tractor until repaired
   / Kioti ck25 4/4 not working #3
Yes, all the front axle drive train components keep spinning even with the 4x4 disengaged, so if there is, for instance, a bad bearing or broken gear, it can cause even more damage to the rest of the axle.
   / Kioti ck25 4/4 not working #4
Is it mechanical engaging 4x4 or is there an electronic switch to engage 4x4.
If its electronic it may be a simple relay issue.
Thanks all. Guess I better fix it before I make things worse.
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A50860)
UNUSED Grey...
2025 Swict 78in Bucket Skid Steer Attachment (A49346)
2025 Swict 78in...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A48081)
2013 Crane Carrier...
