kioti 3054 brake issues
/ kioti 3054 brake issues #1
jpetz42
Three Forks, MT
Kioti 3054
Hello,
I recently bought a 1995 Kioti 3054 w/488hrs. When i bought the tractor I was aware that the breaks would stick down if they were engaged and it was required to manually pull them back out. I was hoping that after working the tractor for a few hours that the breaks would loosen up on there own. Well I was wrong. they still like to stick. I've checked the springs and hit the pivot pin with some wd-40. Any other ideas?
/ kioti 3054 brake issues #2
I would continue to work on the brake pedal pivot; if that grease zerk has been ignored, the pedal will bind on the shaft. Follow the linkage back to the brake cases on the rear axle housing and spray the brake cams where they exit the case, both sides(brakes). I would get some PB Blaster or something similar for a penetrant, I'm not a big fan of WD unless I'm removing decals
LAND PRIDE 10' HYD 6 WAY BLADE (A64278)
LAND PRIDE 10' HYD...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
