Kioti 2410 wont start
/ Kioti 2410 wont start #1
BigJoe67
Kioti CS2410
I have a Kioti CS2410 which will crank but not fire. I have replaced fuel filter and fuel pump. Taken hose off at fuel injector and when i run the pump, diesel flows. I have no smoke when it cranks. Not sure where to go from here
/ Kioti 2410 wont start #2
Check the fuse for the starter solenoid….
I believe it was the solution in the following scenario. TBD
While checking relays and stop solenoid, I found wire was broken at spade connector. Replaced connector and all is good. Thanks for the responses.
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60430)
2016 WANCO WTSP...
