king kutter brush hog
/ king kutter brush hog #1
mopar
fort plain ny
John Deere 4310 ehydro mfwd
hi to all,spring is coming and i'm looking at a brush hog for our new jd4310 ehydro.we have light stuff mostly less than an 1" and maybe some a little more than 1".i'm looking at a king kutter at tsc 595.00 for 5' model and looking for opinions on them,any good?? will driveshaft and hitch hook right up to our unit with out mods?should i get the slip clutch?i also see they have different gear box ratings on the std duty kutters,do i need more than the std 40 hp gear box tractor pto is only 25hp on this unit.thanks
/ king kutter brush hog #2
<font color="blue">...should i get the slip clutch?...do i need more than the std 40 hp gear box tractor pto is only 25hp on this unit </font>
For about ~ $100. extra, get the optional slip-clutch, especially if you plan on lots of brush hogging... well worth the time/aggravation saver... and it gives you one more safety cushion for your tractor's PTO...
I ran a "40 HP" KK gearbox continuously on a 52 PTO hp MF... without any problems... with your 25 PTO hp driving it... the gearbox should last forever... /forums/images/graemlins/smile.gif
sounds like you like your kingkutter,is that what you had on in all those tutorial pictures? /forums/images/graemlins/grin.gifthanks for the info on the gear box,i didn't think i would have a problem there.did you have to cut the pto shaft to use the unit?
/ king kutter brush hog #4
For what it's worth, TSC's around here are selling the 5' KK brush hogs for $549.99. /forums/images/graemlins/smile.gif I'm guessing the difference is related to our relative distances from the manufacturer. I think KK is made in Alabama somewhere.
thanks,i've seen different reports on here of between 500-600 dollars for the unit,maybe they will run a special and make my decision easier. /forums/images/graemlins/smile.gif
/ king kutter brush hog #6
<font color="blue">… sounds like you like your kingkutter,is that what you had on in all those tutorial pictures?...</font>
Yes… that was me… I’m guilty of abusing that poor girl… Different times, I’d forget and thought she was a tree cutter… and really & truly cut some 4-5” stuff… slowly but she cut it… all with that 40 hp gearbox! (Don’t do this at home! /forums/images/graemlins/wink.gif)
If the KingKutter could survive me and the torture I dished out… it should last you indefinitely… /forums/images/graemlins/grin.gif
/ king kutter brush hog #7
John,
Am I seeing you running this KK without chainguards? I would imagine you recommend those, don't you? Also, for something like this KK, could you share the pro's and con's of shear pins vs. a slip clutch? Lastly, is the slip clutch on something like this in the gearbox itself or is it incorporated into a different PTO shaft? Thanks for your help with this.
/ king kutter brush hog #8
Gary,
You will need the Free Acrobat Reader to view THIS CATALOG. Check out the top right side of page 29 and you will see a slip clutch. It goes on the rotary cutter gear box shaft then you mount the PTO shaft on it.
/ king kutter brush hog #9
<font color="blue">... the pro's and con's of shear pins vs. a slip clutch?... </font>
Hi Gary,
The brush/saplings I am cutting would go through shear bolts like no tomorrow... Yes, the slip-clutch is mandatory with serious cutting... (on the 40 HP OMNI gearbox KK and many other's use, it's a smooth input shaft, so I used a Eurocardan slip-clutch with a Grade 8 bolt holding the slip-clutch on the shaft)
I cut mostly my property, very very very rural... no residences within 300 ft... in fact nothing within ~ 1/2 mile? But, this year I am putting some front chains on... for ME!
The KingKutter got a hold of the stuff and threw it... but the Brown rotary cutter is even nastier (7' blade tip speed is ~ 202 mph...) /forums/images/graemlins/shocked.gif
/ king kutter brush hog #10
So I can add a slip clutch feature to a KK rotary cutter by just buying one of these and sticking it on one end of my drive shaft? Amazing... I thought at the very least I'd be buying a new drive shaft or something.
Once again TBN comes through with not only the answers and color pictures to boot! You guys are the best. Thanks. /forums/images/graemlins/smile.gif
/ king kutter brush hog #11
</font><font color="blue" class="small">( So I can add a slip clutch feature to a KK rotary cutter by just buying one of these and sticking it on one end of my drive shaft? Amazing... I thought at the very least I'd be buying a new drive shaft or something. )</font>
Yes,
That is what I recently did. But the driveshaft then needed to be shortened. Slip clutch at Tractor Supply was around $95.
2005 John Deere 7420 (A60462)
2005 John Deere...
NEW 2025 Trailer by Premiere Single Axle 12' Tilt  (A62679)
NEW 2025 Trailer...
Dodge 5500 Bucket Truck (A63688)
Dodge 5500 Bucket...
2010 Chevrolet HHR SUV (A61574)
2010 Chevrolet HHR...
7888SFL (A61567)
7888SFL (A61567)
2013 Nissan Pathfinder 4x4 SUV (A61574)
2013 Nissan...
