king kutter brush hog
/ king kutter brush hog #1
porta mill
in the process of buting a 84"king kutter brush hog to replace on old worn out internationl . it seem to be built pretty well and the price is rigth . i am asking if any one has one and if they are happy with it . It only gets used two to three time a year and and only does 15 acres
/ king kutter brush hog #2
have a 60" Kk for three years now and cut once a month no problem with it Jeeper
/ king kutter brush hog #3
I've had a KK 5' Standard Duty for the last 3 years. I mow about 15 ac marsh grass / heavy weeds twice a year for deer hunting. No problems whatsoever.
There are better, heavier-duty units out there, but at $459.99 I couldn't go wrong for my purposes.
I did remove the tail wheel though, as it always seemed to be in the way when mowing tight areas, and easily became clogged to the point of not turning with the marsh grass. The stuff I cut is 3-5ft tall on average.
/ king kutter brush hog #4
I have a 72" and it works fine. I have hit hard fieldstones the size of volleyballs with it, and it has never failed me (chipped the blades and dented the mower slightly though). Sidewalls are very thick. My only issues with it are: 1) minimum cutting height is around 5" which is higher than most; 2) it windrows pretty bad.
It cuts brush and trees like they are nothing, but due to the flat blades it has little lift to suck up the grass/weeds that the tires rolls down.
Overall I'd say it is "good" and well worth the money for all around cutting needs. "Very Good" if you are not concerned with a quality cut.
thanks for the input , ordered it yesterday hope this one works as well as all yours have .
/ king kutter brush hog #6
I have one of the old red 5' kk economy duty hogs.. had it for 8ys now.. no problems.. used to used it every few weeks..for about 4ys.. now it only gets used for corner trim work and cutitng between trees every few months since i use bigger hogs now..
soundguy
/ king kutter brush hog #7
The used 5' King Kutter that was my ol' 9N when I bought it I retired last year after nearly 20 years of abuse by myself. It still worked fine but it had a lot of rust and the second re-skinning was in bad shape. The biggest issue was the skid bell under the blades was pretty shot and I thought it best in the interest of safety to retire it. I got a new one, nearly identicle at TSC. I don't think that you can get a better buy for personal use.
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
FIXED FIFTH WHEEL ATTACHMENT (A67714)
FIXED FIFTH WHEEL...
2020 Chevrolet Utility Van (A64911)
2020 Chevrolet...
2017 TAKEUCHI TL8 SKID STEER (A65056)
2017 TAKEUCHI TL8...
2000 Ford F-250 4x4 Service Truck (A66736)
2000 Ford F-250...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
