Keeping throttle tension
/ Keeping throttle tension #1
SailorBob
Mobile, AL
Yanmar YM1700
On my 1700 the throttle tension keeps working loose. It only has the hand throttle -- no foot pedal.. I have to tighten it about every other time I use the tractor. When it gets loose the engine speed will drop if I don't hold the throttle lever with my hand.. There are 2 nuts and a washer that hold the lever to the housing. Maybe there is something missing. Anyone else have this problem?
/ Keeping throttle tension #2
With 2 nuts, it should not come loose. one nut adjusts tension, the other locks the first in place. It requires 2 wrenches to tighten.
I don't think the nuts are vibrating loose. I wonder if there issupposed to be a teflon disk like on the the 3 point lever?
/ Keeping throttle tension #4
I agree that there should be a friction washer in the setup. Would also suggest to use an elastic lock nut which is easier to use than two std nuts.
/ Keeping throttle tension #6
There is a friction washer. Check out Hoye tractor web site for parts breakdown. I need one too for my throttle and 3ph as they both vibrate down very slowly.
Jerry
2000BD Koyker120 BB, 5' Bush Hog
I think you may have nailed it. I don't recall seeing the friction disc. I will compare the diagram to the tractor tomorrow. I have to disc a garden tomorrow and it would be nice to not have to fight with it.
Thanks for your help everyone
/ Keeping throttle tension #9
Your friction washer probably fell apart . That's what happened to mine .I replaced it last week.
AS it turns out the friction washer was the issue. Someone had replaced the friction washer with a piece of inner tube cut to roughly the same dimension as the washer. The main problem was it was had a split across the hole letting it slip out of place.
/ Keeping throttle tension #11
The original was rubber similar to inner tube material. The replacement part is a hard washer.
2014 Lincoln MKS Sedan (A64557)
2014 Lincoln MKS...
2006 HEIL 200BBL CRUDE TANKER (A65643)
2006 HEIL 200BBL...
2012 UTILITY VS2RA 53X102 T/A REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
12x20 Car Port (A65640)
12x20 Car Port...
90in. Work Bench (A65640)
90in. Work Bench...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
