Keeping throttle tension
/ Keeping throttle tension #1
SailorBob
Mobile, AL
Yanmar YM1700
On my 1700 the throttle tension keeps working loose. It only has the hand throttle -- no foot pedal.. I have to tighten it about every other time I use the tractor. When it gets loose the engine speed will drop if I don't hold the throttle lever with my hand.. There are 2 nuts and a washer that hold the lever to the housing. Maybe there is something missing. Anyone else have this problem?
/ Keeping throttle tension #2
With 2 nuts, it should not come loose. one nut adjusts tension, the other locks the first in place. It requires 2 wrenches to tighten.
I don't think the nuts are vibrating loose. I wonder if there issupposed to be a teflon disk like on the the 3 point lever?
/ Keeping throttle tension #4
I agree that there should be a friction washer in the setup. Would also suggest to use an elastic lock nut which is easier to use than two std nuts.
/ Keeping throttle tension #6
There is a friction washer. Check out Hoye tractor web site for parts breakdown. I need one too for my throttle and 3ph as they both vibrate down very slowly.
Jerry
2000BD Koyker120 BB, 5' Bush Hog
I think you may have nailed it. I don't recall seeing the friction disc. I will compare the diagram to the tractor tomorrow. I have to disc a garden tomorrow and it would be nice to not have to fight with it.
Thanks for your help everyone
/ Keeping throttle tension #9
Your friction washer probably fell apart . That's what happened to mine .I replaced it last week.
AS it turns out the friction washer was the issue. Someone had replaced the friction washer with a piece of inner tube cut to roughly the same dimension as the washer. The main problem was it was had a split across the hole letting it slip out of place.
/ Keeping throttle tension #11
The original was rubber similar to inner tube material. The replacement part is a hard washer.
PALLET OF SUMP PUMPS (A68842)
PALLET OF SUMP...
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
NEW HOLLAND 110TL LOADER ATTACHMENT (A67714)
NEW HOLLAND 110TL...
15-19.5 Tire and Wheel (A68134)
15-19.5 Tire and...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2015 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2015 Kenworth T800...
