Keeping a cylinder from bending
   / Keeping a cylinder from bending #1
bdog
Elite Member
Texas
John Deere 6130M
I have a machine with a mast that uses a hydraulic cylinder to rotate the mast 90 degrees - vertical for in use and horizontal for travel. There is never any kind of load on the mast except for the mast itself. The mast weighs about 1000lbs but is well balanced and pivots freely. Two people can pivot it by hand. The mast has stops at both the horizontal and vertical positions to keep it from over rotating.
What happened is when rotating it to the horizontal I very briefly held the control lever after the mast hit the stop and it bent the rod in the cylinder. It was not an extreme or careless thing I could see it easily happening again. Current cylinder is 2.5" bore with 1.25" rod. I see bigger cylinders with 4" bore and 2" rod - would this help or would there just be more force to bend the larger rod?
   / Keeping a cylinder from bending #2
Do you have any pictures? How long is the cylinder?
I don't have any pictures but may be able to take some later. The cylinder is a 28" stroke, I think 38" retracted and 66" extended.
   / Keeping a cylinder from bending #4
You must use stops on or in the cylinder as well as stops on the boom. Using external stops to compensate for a cylinder that has to long of a throw is a bad design. Either modifying the cylinder or the mounts so the travel of the boom and cylinder are equal is necessary.
Parts like these are available for external use, or ones can be machined to go inside the cylinder: Quality Farm Supply - Hydraulic Cylinder Stroke Controls
   / Keeping a cylinder from bending #5
The longer the cylinder, the worse the problem. If the cylinder isnt stopping because it is running out of travel, when you hit the mechanical stop at the end, it is still trying to deliver full pressure, and with that much rod exposed, something has gotta give.
If you look on baileynet.com (they sell cylinders) and I have seen it other places too, but they always list column load. I just looked up a 2.5" x 30" cylinder with 1-1/4" rod, and max column load is only 5500#.
Now if you are delivering 2500psi, thats about 12000# of force, and easy to see why it bends.
Going to a larger bore and larger rod may help. But keep in mind, while you are increasing the colum load spec, you are also increasing the force you can deliver with the cylinder, so likely could still happen. BUT.....since if you are moving the mast with 2500psi and a 2.5" cylinder, a 4" cylinder would likely only need 1000psi or less. So....
In a nutshell, you can go with the larger bore, but I would put a pressure regulator on the system so as to no be using any more force than the 2.5" cylinder did.
   / Keeping a cylinder from bending #6
Theoretically, you can't bend a rod with force that is truly straight on along it's axis. Of course that's only in theory, and plenty of rods have been bent. Did the rod or cylinder itself come into contact with anything else that would have induced side loading on it? Are the ends free to rotate smoothly?
If everything was right, and this really is a case of buckling the rod due to sheer hydraulic force, you want a cylinder that has a greater ratio of rod diameter to piston diameter... OR you want to put a pressure regulator (or lower relief valve) into the line... OR you want to set your main relief valve lower.
Just speculating there. I'm no hydraulic man by any stretch of the imagination.
xtn
   / Keeping a cylinder from bending #7
Only way to ensure that this won't happen again is to redesign the movement mechanism so you can use a shorter ram stroke to get the full range movement you want on that mast.
Good luck.
   / Keeping a cylinder from bending #8
Another option too....
Assuming this is when "lowering" the mast to horizontal, once you get close to the stops, killpower, actuate valve, and let gravity do the rest.
I bought my cylinder at bailey. It specs a 6240lb column load. I am not familiar with pressure regulators - how do they hook up just inline with cylinder? I actually have 3000psi as this is hooked up to a skid steer.
xtn
The cylinder did not contact anything. I am interested in regulating the pressure to this cylinder only, but not the main relief as I have other cylinders and motors that need full pressure.
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
Schumacher Jump Box (A54865)
Schumacher Jump...
2013 Ford Edge (A55853)
2013 Ford Edge...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
