Keep from tipping
/ Keep from tipping #21
You could also carry less in the loader and try to keep it on the uphill side of the bucket. Two safe trips are better than one rollover any day of the week.
/ Keep from tipping #22
Done that often myself. Had to tie a big stump off center to the high side of the bucket to wrestle it up the hill a while back.
I always keep my hand on the loader valve when in precarious positions, ready to drop it if things get spooky.
/ Keep from tipping #23
I had some spooky time yesterday. A while back, a big maple went down in a storm. I was considering making lumber out of it, so had it all cleaned up except for a 32 foot log, about 18 inches at the small end. I decided I had enough lumber, so the log is becoming firewood.
I cut it into 4 sections and used the grapple to grab each one, rolled the bucket back and lifted them. The tractor lifted them all right, but the tree was laying perpendicular to a 20% or so slope which I needed to carry them across, no up due to a fence, no down due to trees, gas meter, etc. I have no idea what each section weighs, but they did take considerable weight off the rear tires when I picked up.
With a log loaded, 900 lb on the hitch and 250 or so on the wheels, the tractor still had a pronounced tendency to move sideways down the hill as I crossed it. I had to countersteer the entire distance to the driveway, either forwards or backwards. It felt stable, wasn't tilted too much, just kept wanting to move downhhill as it went along. I went VERY slowly with both the bucket and rear weight just off the ground.
/ Keep from tipping #24
daTecha, Hope it was less stressful than the post read. Had me on the edge of my seat reading you were at 20% with that load. Sometimes things just need doing and the maniac in us has some useful purpose. Tough to know when to call that off in every instance though. Be safe wildman :)
/ Keep from tipping #25
If it feels a little tippy, then you really need to be careful. May times I have driven over an area and everything is ok. A rock drops off the loader and the next time I go over the area I end up with a tire in the air because of the rock. Haven't tipped yet, but there have been some close calls with the loader full and driving over little rocks. Just added about 300lbs to my box blade and the tractor is starting to feel solid with full loads.
Would say hang in there, but it maybe better to jump
/ Keep from tipping #26
The tractor felt stable enough, no signs of wheels coming up and stuff like that. I was moving about 25 yards to the driveway. The recently fabricated and installed wheel weights make a big difference. I was just surprized that it wanted to move downhill, despite having Ag tires and not tearing up the grass. It was definitely low and slow as you go time, and there was some pucker factor involved, but it all felt stable except for the tendency to move downhill instead of across it. If I was going much further, I would have cut it into smaller sections, but this way, all the mess that comes with cutting and splitting is in the barnyard instead of the lawn.
/ Keep from tipping #27
Rich,
I know you are a pretty safe operator but I wanted to remind you
When you turn the wheels away from the sliding direction the tractor becomes even more subject to tipping than if you steer into the sliding direction. I realize you had very little room to manuever but just keep that in mind. To me, that in itself is an indicator of approaching the "pucker factor":D and I'll try to re-position at that point...if I can??
/ Keep from tipping #28
I have read that if an imaginary plumb line drawn from your most puckered part fell on the inside of your rear wheel you were ok. If it fell on the outside you were already tipping over.
/ Keep from tipping #29
With your quads, which rear wheel?:D
Bob
/ Keep from tipping #30
That plumb line rule of pucker would be affected a lot by where the seat is located. My DX seat is way higher than on an 8N, which is about the same size and weight. My personal sense of tipping is much enhanced by the higher seat since I get farther out of "plumb" with less tilt.
For the countersteering thing, I turned the wheels to direct the front end up the hill. Sometimes one way, sometimes the other, depending on whether I was going backwards or forwards. As I rethink the situation, it was the front end that tried to go downhill and the back end just followed along. The rears weren't sliding. So, when I was going backwards, the tractor tended to rotate the nose downhill, making the rear go uphill and being in reverse I tended to climb up toward the fence and woodpile. Going forwards, the front tended to slide downhill too, and the travel direction was toward the trees and gas meter. There was no real sense of roll instability, just a lack of normal directional control, kind of like driving with bald front tires on ice.
I'm pretty sure I couldn't/wouldn't have done it without the new rear wheel weights. Those things really make a difference. I'm probably going to add another 40 or so pounds to each side and maybe cut some of the concrete off the 3 point weight. 1300 lb total rear weight seems excessive -- that's like having my old B7100 as a counterweight.
Okay, topic change. I just tried to put a smiley on the end of that paragraph. I clicked on the icon and it went up in the title. Now I can't get it to go away. Where do I click to put the smiley in the text and not the title and how do I erase the one in the title?
/ Keep from tipping #31
Hey guys, just curious, but I thought I read somewhere that a partial filling (of the tires) was very dangerous. Leaves too much room in the tire for the liquid to slosh around and could create traction/control problems when trying to stop and manuever. Obviously would not want this on a hill.
Does this make sense? Any truth to this?
Would love to do a parital fill of mine, but, was told to go 75% to at least fully cover the rim to avoid rusting and avoid the sloshing.
/ Keep from tipping #32
Go to options (I think??? :confused: ) and choose advanced editor.
Bob
/ Keep from tipping #33
I got my rear tires filled and I am really having no problem mowing with the, and I have slopes. I just try to be careful, when I I think the tractor is gonna slip, and i noticed I have less trouble with traction digs.
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Coleman Back Home Screen House (A62613)
Coleman Back Home...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
Blue Diamond Brush Cutter (A64126)
Blue Diamond Brush...
