Kawasaki engine problem
/ Kawasaki engine problem #1
smstonypoint
Super Member
SC (Upstate) & NC (Piedmont)
NH TN 55, Kubota B2320 & RTV 900, Bad Boy Outlaw ZTR
I have a relatively new ZTR (with less than 70 hours of use) with a 31 hp Kawasaki engine (air-cooled 2 cylinder). When I was mowing 3 weeks ago, the engine lost power and backfired after 1.25 hours or so of use. I parked the mower for the night with the intention of staring at the engine the next day. ( I say "stare" because the extent of my mechanical knowledge keeps me from doing much more.:))
The next day, the engine started and ran fine as I finished up mowing for .25 hours or so.
I mowed again last week, and the same problem reappeared after mowing about the same amount of time (1.25 hours or so).
Am I way off base in thinking that I have a faulty ignition coil?
Thanks in advance for any help.
Steve
/ Kawasaki engine problem #2
check the vent on the gas tank,may be plugged.Maybe fuel starved after running a
while and then vents itself after sitting.
Dan,
Thanks for the info -- I will check the vent. Would a clogged vent cause the backfiring?
Steve
/ Kawasaki engine problem #4
think they had a recall on the fuel filter maybe check there
My problem turned out to be a faulty ignition coil. Per the recommendation of my local small-engine repairman (shade-tree variety), I had both coils replaced.
I have discovered that Kawasaki is very proud of its replacement parts -- $49+ per coil. OUCH!!!!!!!:(
Steve
/ Kawasaki engine problem #6
Thanks for replying with the cause of your problem
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
CASE CX160D EXCAVATOR (A65053)
CASE CX160D...
2012 SOUTHERN 130 BBL VACUUM TRAILER (A65643)
2012 SOUTHERN 130...
Kubota L2501D 4x4 Utility Tractor with Land Pride 72in Brush Cutter (A64553)
Kubota L2501D 4x4...
10ft. Barge Box Wagon with Hoist (A65640)
10ft. Barge Box...
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
