KAMA 554 Horsepower
/ KAMA 554 Horsepower #1
psj12
Platinum Member
Short OK
KIOTI 551
Hi I am new to this board.
I have a KAMA 554 on order and the dealer told me the engine has been derated from 55 hp to 50 by reducing the max loaded rpm. This is done to meet EPA/import regulations.
What I would like to know is, how to readjust the fuel pump govenor to deliver the reated 55 hp at the rated rpm. Thanks.
/ KAMA 554 Horsepower #2
Well if they did it with RPM, then they changed the gearing of the transmission. They still need to provide a 540 PTO RPM and that is usually done at the engine rated HP RPM. Change the gear ratio and the engine runs at a different RPM to get the rated PTO RPM. You could re-adjust your governor to get the higher RPm but without changeing some gearing your PTO would be too fast.
/ KAMA 554 Horsepower #3
Which engine version is indicated by the engine plate - the 495T1 or the 495T? And what is the RPM range covered by the green band on your tachometer?
//greg//
/ KAMA 554 Horsepower #4
I had my 554 come and it was a total pooch on power. I checked timing and it was good. Then i adjusted the rack adjustment on the pump and got my power back. The rack was so far adjusted back that i could not even get black smoke if i lugged the engine to a stall. I think it only took about 3/4 turn on the rack screw and i probably doubled my power that was felt. Now i get a small amount of black when i stab the throttle and really lug it down.
/ KAMA 554 Horsepower #5
How do you access this adjustment and who did you know it was right? I have a 454 that is a little slugish when in transport mode using high gears.
Patrick
/ KAMA 554 Horsepower #6
schmalts...
Where is the rack adjustment on the 554? I'd like to try adjusting my 554 to see if it makes more power in high gear as well...
Greg...
Whats the difference between the T and T1 engine?
Thanks, Rob
Greg-g, I have not yet received the tractor so I cannot answer specific questions about hte engine type. I am also looking for more specific instructions as to where the rack adjustment is.
/ KAMA 554 Horsepower #8
</font><font color="blue" class="small">( Whats the difference between the T and T1 engine?)</font>
Output power mainly, and how they obtain it; 38.2KW for the 495T1 and 44.1KW for the 495T, neither of which computes to 55hp. Since they don't use the same model governor. It makes a difference to how much the output can be tweaked - and in which direction.
//greg//
/ KAMA 554 Horsepower #9
The adjustment is the threaded rod sticking out of the back of the injection pump with a lock nut on it. It has a cap on it that is safety wired. cut the safety wire, (if you bought from a dealer ask if it voids warrenty) remove the cap, and hold the screw with a screwdriver when you break the lock nut loose so you don't move the screw when you turn the lock nut (kind of like adjusting the valves) You need to make small adjustments like 1/4 turn at a time. This screw adjusts the amount of displacement that your injection pump pistons have so you are actually metering how much fuel your injector will put in under max load. Be careful and do not go gonzo just because you are still getting more power because if you go too far you can add too much heat into the engine.
you will notice a difference in the rev up speed if it was out of adjustment. You should see a small amount of black smoke on a hard rev. if your rev is really sluggish and there is no smoke it would seem you could get a bit more power from adding more fuel. If you are driving your tractor in 4th gear on the road and needing more than 1/2 throttle on flat ground i would think you are under powered. Mine i actually had to down shift to 2nd gear on a moderate hill on an asphalt road!!! now i just floor it and power up it in 4th gear.
I estimate my HP was set at not much more than 30hp from the factory. This also greatly helped my starting performance in cold weather but then again , mine was really out of adjustment.
While cruising down the road in 4th gear at 3/4 rpm range you should see a little black smoke if you suddenly floor the pedal and then the smoke should go away as it starts to respond. Mine was just not responding to this, and if i hit a small hill and didnt down shift my rpm's would drop from lack of power and i could lug it down to 1200rpm and there still was no black smoke. The engine was starving.
I cannot believe it was that far out of adjustment and all i can think is that the pump they put on mine was pre-adjusted for a smaller HP engine. Not that that would ever happen in china /forums/images/graemlins/wink.gif
Keep in mind that this adjustment only affects the power when the engine is under load. this is adjusting the maximum amount of fuel your engine will get so you will not notice any difference at low throttle or idle.
/ KAMA 554 Horsepower #10
<font color="blue"> </font>
schmalts...
Which direction do you turn the screw (Clockwise or counter clockwise) to increase/decrease fuel displacement?
/ KAMA 554 Horsepower #11
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Whats the difference between the T and T1 engine?)</font>
//greg// )</font>
Hey Greg,
I went up to visit my tractor this weekend and took this picture of the engine label on my 554. It is stamped saying the engine is a 495T2. Do you know anything about that?
Also, I have not heard anything further from (schmalts) about which way to adjust the injection pump to add horsepower so I have not tried that. Do you know anything about that, as well?
Does anyone have any experience with adjusting the rack yet?
/ KAMA 554 Horsepower #12
I'm sorry, but I have nothing on that variant. The 495T puts out 44.1KW @ 2500 rpm with a T-300-1250Z governor. The 495T1 puts out 38.2 @ 2400 rpm with a T-300-1200Z governor.
Unless they detuned the 495T, your T2 variant with 40.5KW @ 2300 may have yet a different governor. What is the PTO rpm range marked on your tach?
//greg//
/ KAMA 554 Horsepower #13
</font><font color="blue" class="small">( Unless they detuned the 495T, your T2 variant with 40.5KW @ 2300 may have yet a different governor. What is the PTO rpm range marked on your tach?)</font>
Here is another picture of another label saying it is 55HP. I'm home and will have to look at the PTO rpm range before answering that question.
Oh, and in regards to the rack adjustment...is that a for real thing, you think?
/ KAMA 554 Horsepower #14
</font><font color="blue" class="small">( Here is another picture of another label saying it is 55HP....Oh, and in regards to the rack adjustment...is that a for real thing, you think? )</font>
I don't recall saying you didn't have 55hp. But just for the record, 40.5KW is actually 54.3hp. Pretty sure I said my book only listed the 495T and 495T1, and neither of THEM had a 55hp rating (59.14 for the 495T and 51.23 for the 495T1)
Your -T2 could be the -T model with the throttle stop backed off by 200 rpm. The PTO rpms might be an indicator, but to be sure you'd have to know the governor model.
Adjusting the throttle stop shouldn't pose any problems, but I'd think seriously before fooling with the governor itself - especially while you're still under warranty.
//greg//
/ KAMA 554 Horsepower #15
[quote
I don't recall saying you didn't have 55hp. But just for the record, 40.5KW is actually 54.3hp. Pretty sure I said my book only listed the 495T and 495T1, and neither of THEM had a 55hp rating (59.14 for the 495T and 51.23 for the 495T1)...)</font>
You are correct in that recollection...and I don't recall saying that I don't have 55HP either. I put the photo in to provide additional information to help you in the identifying process.
I was not aware of the T2 engine and it's not listed in my spec manuals. The manual lists the 495T rated @ 2500 rpm, 495T1 rated @ 2400 rpm. Does your book also list a 495C and 495D rated at lower rpm's, 2000 and 1500 respectively with different Governor models?
I did notice on the engine label (1st photo) the rpm rating is 2300, backed of by 200 r's as you suggested. This leads me to think that the governor model might be the same as one of the two...making power at different rpm ratings.
Assuming this to be the case, are you saying then, I could adjust the throttle stop a hundred rpm or so with no problems? If so, I'll try that before screwing with the rack on the injector. One more thing, the wire that runs from the rack adjustment cap also runs through the throttle stop. So I would have to cut that anyway to adjust it.
I'll be going up again this weekend and see what the governor model is, whether it's a T-300-1250Z as on the 495T or T-300-1200Z as on the 495T1.
2017 Ford Expedition SUV (A64557)
2017 Ford...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2024 CATERPILLAR 304 EXCAVATOR (A65053)
2024 CATERPILLAR...
2016 Isuzu NRR Elgin Broom Badger Sweeper Truck (A64556)
2016 Isuzu NRR...
