Oil & Fuel Kabota
/ Kabota #1
err54
Rutland
b7100 hstd kabota
I have b7100 hst d Kobota I changed the hst filter, it is located uinder the seat, when i start the tractor it as way to much preasure and blows the gasket of the filter, the serial number is the older version 13000 i think it has a release valve stuck, the parts manual doesnt show where these valves are located at. has any one had this happen
/ Kabota #2
Are you saying the gasket itself blew out or,
is it just still leaking around the gasket.
I'm not too sure, but I don't think there's that much pressure there.
Could it be a cracked housing.
/ Kabota #3
It only did this after the new filter was installed?
/ Kabota #4
could be the wrong filter. check it, needs to be a HST filter not a hydraulic filter.
/ Kabota #5
My brother loves to give everything the old factory-over-torque. He blew a gasket on an oil filter once by over-tightening it. Perhaps you over-tightened yours too.
3Pt Hydraulic Post Driver (A66408)
3Pt Hydraulic Post...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65054)
2001...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
Landhero...
Landhero...
International 311 6ft. Pull Behind Mower (A65640)
International 311...
