Oil & Fuel Kabota
/ Kabota #1
err54
Rutland
b7100 hstd kabota
I have b7100 hst d Kobota I changed the hst filter, it is located uinder the seat, when i start the tractor it as way to much preasure and blows the gasket of the filter, the serial number is the older version 13000 i think it has a release valve stuck, the parts manual doesnt show where these valves are located at. has any one had this happen
/ Kabota #2
Are you saying the gasket itself blew out or,
is it just still leaking around the gasket.
I'm not too sure, but I don't think there's that much pressure there.
Could it be a cracked housing.
/ Kabota #3
It only did this after the new filter was installed?
/ Kabota #4
could be the wrong filter. check it, needs to be a HST filter not a hydraulic filter.
/ Kabota #5
My brother loves to give everything the old factory-over-torque. He blew a gasket on an oil filter once by over-tightening it. Perhaps you over-tightened yours too.
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
Linx EQ07020RS 20ft Trailer (A65640)
Linx EQ07020RS...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2T Chain Lever Hoist (A66408)
2T Chain Lever...
CHEVY DUALLY TRUCK BED (A65643)
CHEVY DUALLY TRUCK...
