K800-3 wont start
/ K800-3 wont start #1
tbobinac
bobcat 753
Hello,
We have a mini kubota k800-3. It was running fine, than we went to start it and it won't turn over. It cranks and cranks but will not turn over. We have changed the fuel filter, air filter, glow plugs, starter, fuel, battery, and fuel solenoid. We have checked the lines to make sure the fuel is pumping through the lines. Any thoughts would be greatly appreciated.
/ K800-3 wont start #2
To make it easier for you..
Crank and cranks IS turning over..
U mean it cranks but won’t start..
Are u getting fuel thru the lines AT THE INJECTORS.?
Have u tried removing the shut off solenoid and trying to start it.??
Do u have fuel in the tank AND the fuel shut off valve in the run position.??
If yes to all this then, if u have fuel up to the pump inlet and nothing out, u have inj. pump problems..
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
3PT BOG HARROW (A63291)
3PT BOG HARROW...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
2016 Dodge Grand Caravan Van (A61574)
2016 Dodge Grand...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
