Just got this 1990 1920 with fel and back hoe (2003)
   / Just got this 1990 1920 with fel and back hoe (2003) #21
It still moves just have to start it in gear. Plan on taking fel and hoe off then it goes into garage for a make over all fluids hoses belt paint everything freed up and lubed it will role out the door like a new one
New rubber mats for the step areas are ridiculously expensive. I seem to remember the price quoted was almost $300.
You can get the quart(?) size can of Herculiner, (pickup bed liner material) and put a beautiful, black, wear resistant finish, on your step areas.
Thats a good idea
You can make a wooden dowel clutch alignment tool. Some clutches actually are supplied with the alignment tool.
The one i saw in the generic service manual had a thing you slipped over the shaft i thing for setting the fingers maybe. I'll have to look it up and post a picture of it
This is what i was talking about. My buddy says we can take a measurement off the fly wheel with a depth gauge. And from what i have read on line these are just about impossible to get a hold of
   / Just got this 1990 1920 with fel and back hoe (2003) #25
   / Just got this 1990 1920 with fel and back hoe (2003) #26
View attachment 494626View attachment 494627View attachment 494626
You aren't going to be doing any of this. Relax. Split the tractor, get the parts and give it a go. Get the disk aligned the best you can and try to push things together. if not, try again and maybe use a screwdriver to line things up. It will go together just fine.
Hmm just found out this is a 1997 not a 1990. 7 years newer cant be bad
   / Just got this 1990 1920 with fel and back hoe (2003) #28
Of course you are correct, but I do not believe there is any significant difference.
   / Just got this 1990 1920 with fel and back hoe (2003) #29
Yes i know just makes everything even better. Better deal same price but it's 7 years newer
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2017 Kubota M7-151 Premium MFWD Tractor (A56435)
2017 Kubota M7-151...
2007 INTERNATIONAL 9200I (A58214)
2007 INTERNATIONAL...
2019 Chevrolet Silverado 1500 (A55973)
2019 Chevrolet...
2008 FORD F-750 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-750...
LOT: (9) Tires & Rims: 275/80 R22.5, 275/70 R22.5 and other sizes (A59076)
LOT: (9) Tires &...
