Just got this 1990 1920 with fel and back hoe (2003)
   / Just got this 1990 1920 with fel and back hoe (2003) #21
It still moves just have to start it in gear. Plan on taking fel and hoe off then it goes into garage for a make over all fluids hoses belt paint everything freed up and lubed it will role out the door like a new one
New rubber mats for the step areas are ridiculously expensive. I seem to remember the price quoted was almost $300.
You can get the quart(?) size can of Herculiner, (pickup bed liner material) and put a beautiful, black, wear resistant finish, on your step areas.
Thats a good idea
You can make a wooden dowel clutch alignment tool. Some clutches actually are supplied with the alignment tool.
The one i saw in the generic service manual had a thing you slipped over the shaft i thing for setting the fingers maybe. I'll have to look it up and post a picture of it
This is what i was talking about. My buddy says we can take a measurement off the fly wheel with a depth gauge. And from what i have read on line these are just about impossible to get a hold of
   / Just got this 1990 1920 with fel and back hoe (2003) #25
   / Just got this 1990 1920 with fel and back hoe (2003) #26
View attachment 494626View attachment 494627View attachment 494626
You aren't going to be doing any of this. Relax. Split the tractor, get the parts and give it a go. Get the disk aligned the best you can and try to push things together. if not, try again and maybe use a screwdriver to line things up. It will go together just fine.
Hmm just found out this is a 1997 not a 1990. 7 years newer cant be bad
   / Just got this 1990 1920 with fel and back hoe (2003) #28
Of course you are correct, but I do not believe there is any significant difference.
   / Just got this 1990 1920 with fel and back hoe (2003) #29
Yes i know just makes everything even better. Better deal same price but it's 7 years newer
2019 Ford F-550 Altec AT41S 40ft. Bucket Truck (A55973)
2019 Ford F-550...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
JOHN DEERE 469 BALER (A58214)
JOHN DEERE 469...
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
