Just got this 1990 1920 with fel and back hoe (2003)
   / Just got this 1990 1920 with fel and back hoe (2003) #21
It still moves just have to start it in gear. Plan on taking fel and hoe off then it goes into garage for a make over all fluids hoses belt paint everything freed up and lubed it will role out the door like a new one
New rubber mats for the step areas are ridiculously expensive. I seem to remember the price quoted was almost $300.
You can get the quart(?) size can of Herculiner, (pickup bed liner material) and put a beautiful, black, wear resistant finish, on your step areas.
Thats a good idea
You can make a wooden dowel clutch alignment tool. Some clutches actually are supplied with the alignment tool.
The one i saw in the generic service manual had a thing you slipped over the shaft i thing for setting the fingers maybe. I'll have to look it up and post a picture of it
This is what i was talking about. My buddy says we can take a measurement off the fly wheel with a depth gauge. And from what i have read on line these are just about impossible to get a hold of
   / Just got this 1990 1920 with fel and back hoe (2003) #25
   / Just got this 1990 1920 with fel and back hoe (2003) #26
View attachment 494626View attachment 494627View attachment 494626
You aren't going to be doing any of this. Relax. Split the tractor, get the parts and give it a go. Get the disk aligned the best you can and try to push things together. if not, try again and maybe use a screwdriver to line things up. It will go together just fine.
Hmm just found out this is a 1997 not a 1990. 7 years newer cant be bad
   / Just got this 1990 1920 with fel and back hoe (2003) #28
Of course you are correct, but I do not believe there is any significant difference.
   / Just got this 1990 1920 with fel and back hoe (2003) #29
Yes i know just makes everything even better. Better deal same price but it's 7 years newer
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A58214)
2014 DRAGON...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
2014 Ford F-150 Pickup Truck (A56858)
2014 Ford F-150...
17101 (A55787)
17101 (A55787)
2017 Ford F-650 Mason Dump Truck (A56858)
2017 Ford F-650...
