Just got first TIG rig!
   / Just got first TIG rig!
I used a new flapper disc on the angle grinder and twirled the rod in my fingers. If the cone looks centered is that good enough?
What I really need at this point is the arc start method, I feel like a caveman.
   / Just got first TIG rig! #12
You don't want grinding line to rotate around the tungsten. You want the grind lines to run straight with the tungsten.
Does your welder have high frequency start?
   / Just got first TIG rig! #13
Looks like its a DC only, scratch start machine.
I use a diamond blade on a 4.5 inch grinder to sharpen my tungstens. Turn the grinder upside down, lay the tungstens on the shield and twirl with my fingers to keep the grind lines in line.
   / Just got first TIG rig! #14
Apparently you don't have HF start, So scratch start it like a stick more or less. Of course you get some contamination because you have to touch the tungsten to the work. Some rotate the cup to rotate the end of the tungstun in to the work and then slightly out, but maintaining the arc. When you are set for really low amps (say less than 20) the arc gets harder and harder to start. It requires more concentration.. When you get under 10 amps, the arc is pretty small. Weld up some 12 gauge copper wire with it for fun and practice. Make some "crush washers" like these. Or some little chain. I knew you would like it.. I have been egging you on to get it for years.:)
IMG_20131018_105129_520.jpgIMG_20131018_104229_173.jpgIMG_20131018_115507_563.jpgDSCF0525.JPGDSCF0524.JPGDSCF0520.JPG
OK that seems easy enough to get straight grind lines from an angle grinder (flapper disc).
4th weld is a fillet (the inside of that outside corner). Had trouble at the start & finish but in the middle welded like a hero! :D Lots to learn.
There's so much more going on, the arc length, feeding wire, holding the torch, the foot pedal a lot of coordination to learn. Plus start & stop and heat buildup. Seems like there's so much more heat than MIG welding, maybe because the mig is shoving wire in & phase-changing it? The backside of a MIG weld doesn't burn up like the backside of a TIG weld.
444188d1445047178-just-got-first-tig-rig-1st_3_tigwelds4-0-jpg
So I have scratch-start huh? OK good now I know. Will try the cup method.
How about the middle to the left of the undercut? But not sure that's undercut may be discoloration. Will look again tomorrow when I go back to the shop.
It's hero enough. Even so I wouldn't have the slightest idea (or ability) how to change any aspect of that weld. I was like a one-eyed cat watching four mouse holes.
   / Just got first TIG rig! #19
It looks like just discoloration to me. Cut off both ends leaving only the good weld to show people.
   / Just got first TIG rig! #20
Which explains why my projects all end up being smaller than planned. :)
Terry
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
SDLL30 Loader (A47384)
Pontiac Car (RUNS)(TITLE) (A50774)
Pontiac Car...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
Wolverine 72" Skid Steer Bucket (A50515)
Wolverine 72" Skid...
Land Honor Skid Steer Rock & Tree Hand (A50515)
Land Honor Skid...
