just bought YM2210D
/ just bought YM2210D
Today I dropped off the head at the machine shop to get checked out. Also dropped off the exhaust to be ceramic coated.
/ just bought YM2210D #22
A ceramic coating for the exhaust sounds interesting. I've not encountered it before. Whatever it takes, those old Yanmars are worth getting going again because they last forever.
One of the key maintenance items is to remove and clean the the wire mesh on the cleanable transmission/hydraulic filter. That's a good opportunity to change the old trans/hyd fluid as well. Expect to find that fluid is debased by having some water in it. Rain can seep in past the collar of the shifter.
Also, as it has been sitting outside, you should also check that the gauge in the fuel cap hasn't let water into the fuel tank - best to just drain the tank and fuel filter completely. And also check for water that can leak past the center of the steering wheel and stand in the steering column on top of the steering box.
All these are simple things to deal with, but necessary on these old Yanmars if they sit outside uncovered. A simple tarp thrown over a sitting tractor is sure worth doing.
rScotty
/ just bought YM2210D #23
That V2 loader is a solid indication that tractor has be "refurbished" by this company. They used to sell them as Yanmars, since the lawsuits by Yanmar they now sell them as YNM's. Welcome To Vntractor
was the v2 not OEM? no doubt it was grey market import by one of these companies prior to the lawsuits, but what exactly is meant by"reconditioned". even though i see two different colors of grey, there is no overspray on anything which means it would have had to been taken completely apart and i would not think that to be cost effective.
/ just bought YM2210D #25
I am with winston1 on this. That V2 loader is a 100% no doubt Vietnam rebuild tractor. There are all kinds of horror stories on their rebuilds! With one of the most consistent complains being a worn out engine having minimum repairs done, new paint and hour meter set to zero or new installed.
That being said with no doubts in my mind about it, fix it right while you have it torn down. Even being a Vietnam tractor, repair the engine, rebuild the injection pump, drain the oil, fuel and hydraulic fluid, clean or replace the screen, put new fluids in it and it will probably last if cared for through your grandchildren’s lifetime. They are just that solid if taken care of!
My understanding in reading on the tractors in Japan is not a every year trade, but a trade in as the tractor is paid for based on the fee structure.
That being said with no doubts in my mind about it, fix it right while you have it torn down. Even being a Vietnam tractor, repair the engine, rebuild the injection pump, drain the oil, fuel and hydraulic fluid, clean or replace the screen, put new fluids in it and it will probably last if cared for through your grandchildren痴 lifetime. They are just that solid if taken care of!
thanks everyone for entertaining this dialogue. learning quite a bit about an interesting and convoluted history. it would not surprise me if the meter was replaced. come to think if it it probably looks too good for the rest of the machine. the machine shop should be able to tell me how much wear is on the head.
/ just bought YM2210D #28
In vietnam, labor is very cheap. They take the tractors down as far as needed to make repairs, and repaint.
They take parts off a donor tractor and install them on the tractor they are rebuilding for resale
If a (piston, etc,) is odd size, it doesn't matter as these workers in viernam will never see this tractor again
They are well known to replace the meter, or roll it back to low hours.
Those of us that have been here a while have seen /heard all the 35 yr old low hour tractor stories, that just don't exist.
Good luck with your tractor repairs. I may sell mine for a much newer tractor very soon
/ just bought YM2210D #29
there was once a guy here named Buck ? I believe his company was EFC. He use to post pictures of the factories there with tractors that had been burnt to the ground. These vietnam workers would take this burn up tractor and make it.
Only the worse of the worse went to vietnam for a rebuild, as reputable dealers from the states like Fredricks in Al. only bought the best tractors for resale
/ just bought YM2210D #30
looking back, I found an old post from buck about PTO hp
''I know everybody loves the 20% multiplier but that is a guess at best. The FX335 we ran on the dyno came out at 31.1 hp at the PTO. The AF33 without hydrauilic shuttle ran 33.7 at the PTO. Take that tractor home and expect to run a 40hp implement and it will choke.''
Buck
/ just bought YM2210D #32
you might like looking at some of these tractors pics from an old thread I was mentioning. These workers in VN really can make an old worn out tractor look new again
https://www.tractorbynet.com/forums/yanmar/77035-looking-buy-yanmar.html
That's a great thread! Thanks. It really says it all. I miss all those old posters. Prunty talked about health problems then disappeared, Inspector 507 died recently per an obituary on a different tractor forum. A couple of those legitimate dealers in that thread got harassed so bad by Yanmar-USA that they quit importing Yanmars.
Here's a photo I posted in 2005, this post explains it. In summary I had to buy a real Yanmar fuel filter element and bowl to fit the Genuine Yanmar fuel filter assembly that I saw salvaged off a warranty-return recon, because the recon factory in VN had installed used God-knows-what parts in place of the bowl and element that should have been on there.
The local recon importer where I bought this filter assembly (maybe the West Coast site for that same VN-Tractor company in Texas) went out of business a decade ago, after they were buried with warranty return tractors. The family members running this local outlet were honest, but they were being shipped too many tractors that soon failed.
45759d1128810810-factory-reconditioned-yanmars-750484-img_3186rfuelfilter2-jpg
/ just bought YM2210D #33
My understanding is that Yanmar did not build their own loaders ever, but contracted those out (someone correct me if I am wring on that). I also understand that the loaders at least on the ym Yanmars carried a FYL xxx label.
Good luck with your tractor.
/ just bought YM2210D #34
re loaders: for the US-model YM's the US dealer could install a 'Yanmar' branded loader made by a supplier in North America. I think these are the same loaders as on the Deeres that were built by Yanmar.
For Yanmar-Japan-version tractors, the recon importer I mentioned above had one take-off loader for sale alone, that had arrived on one of their FX (later model) recons. That loader had curved arms and as I recall, compound leverage so the bucket stayed level as the arms were raised. Everything about that loader looked well designed, elegant.
/ just bought YM2210D #35
I did not realize inspector had passed. So many have gone since I became a member
/ just bought YM2210D #36
I guess both were before my time on this forum, but my loss I am sure. I am also sure they were great resources of all things related to these tractors, which is a lost to all of us here.
Happy tractoring to both gentlemen.
/ just bought YM2210D #37
I knew it wasn't a 35 hour grey market tractor "for real". What I believe more is the VN rebuild was bought. Run for 20 hours that first year , once out of warranty a catastraphic breakdown occured and it was parked under that tree for all these years.
/ just bought YM2210D #38
That doesn't mean it can't be made to run good again. The reason why the VN chose those Yanmar tractors is the same as why all of us love them. They are simple machines, and way overbuilt. Easy to repair and parts are available. Get it going and your grandkids will be using it.
rScotty
/ just bought YM2210D #39
rScotty
Totally agree. At their core, these ym yanmars are straight forward mechanical pieces of equipment. Extreme solid and will perform beyond what one would think a compact tractor is capable of.
As I have said in other comments, assume all maintenance is due—change all the fluids, filters, clean the hydraulic screen, fix the head gasket/head and any other issues you may find and it will be around for your great grandchildren to use!
/ just bought YM2210D #40
my guess Buck at EFC (like many other dealers) got out of the yanmar business due to the lawsuit. I guess, leaving Fredricks as the only authorized Grey Yanmar dealer
UNUSED WOLVERINE LAND LEVELER (A64281)
UNUSED WOLVERINE...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2012 Case SV300 Skid Steer (A63111)
2012 Case SV300...
