Just another junk chainsaw
/ Just another junk chainsaw
ok, need opinion.
Looks like I scratched the piston on my 49cc, 18" bar Craftsman.
I see grooves when I take the exhaust off and ring looks damaged too.
Worth fixing, might need a new clamshell, piston and ring?
Anyone know cost for parts?
I already have 2 saws and this was a backup for a while.
Not heavily used for the last 3 years. So surprised it self destructed.
Only if you have another parts saw to steal from or get on the cheap to make a good one from.
I wont put the money into new parts on plastic clamshell saws that can be bought for 50 running myself.
I also explain this to folks bringing them in it is not worth the labor cost and parts cost.
Cheaper to sell them another runner for 50.
/ Just another junk chainsaw #1,162
Yep, I junked my Craftsman (Red cover one) last year due to cylinder damage. Bought a Ryobi from Direct tools.com for $69! It's great actually!
Here's one from there now (just quickly looked to see what they had available)
/ Just another junk chainsaw #1,163
Howdy ! Hey Mr xyz123 couple questions please ?
Is the is the Echo Red armor 2cyl oil all they say it is ? Or IYO "colored snake oil " ???
Also your experience / comments if you may on Tsunami / Sugihara chainsaw bars ???
Thanks in advance !!! ......................
I tried it when it was the old original formula. Then they cheapened it by changing formula but keeping the ridiculous high price. Ester was part of the change. They removed it. It is also semi synthetic.
It's good FD rated oil but IMHO it just cost to darn much. IMO it is over hyped.
I like this 100% synthetic VPracing oil better then high priced RA. IMO VP a better oil and way cheaper to buy too.
IMO just try and use FD rated oils. The have everything in them.
FB corresponds to high lubricity performance but without any low-smoke technology.
FC meets the FB lubricity standards but also is a low-smoke lubricant.
FD corresponds to higher detergency properties than the other two grades, meets the lubricity requirements and has low smoke requirements.
Both of those bars are good bars. Tsu and Sugi. Bar rails are great.
I buy Tsu due to the better pricing. Sugi has more rivets in their tips.
US sugi makes their light weight bars for husky. Overseas Tsu makes their light weight bars for husky.
Another 245 and missing a coil wire. 74cc
I smiled more for the bar cover for the wall over the 670 champ.
Saw needs some fixing for the pro side ext score. Piston kit and cylinder clean up is what I am hoping for.
If you live in Ohio. Friends do a saw fest down by Marysville OH Oct 16th all day.
Eric in pic. Also Grant a stihl timbersports competitor helps run it too.
Stihl 039.
What a cluster
Guy loaned stihl 039 out to one of his workers. Looked like been trenching.
Fixed the broken recoil and removed the boot lace used to try and fix part of that and broken handle.
Missing tank vent so made one up.
Somehow it sheared the key off the flywheel and the flywheel nut is stripped out and wont come off. Just spins. :ROFLMAO:
/ Just another junk chainsaw #1,170
I didn;t know stihl made a portable trencher.
Another reason not to lend out good tools.
/ Just another junk chainsaw #1,171
Just bringing this up I never owned one or had any desire to get one . However maybe one of you old timers would remember probably in mid 80"s Echo came out with a twin cylinder saw . I think it was a CST 610 model aka the Evil Twin. A friend of mine had one in "yellow" sold as a John Deere .
I think he said both cylinders fired on same stroke , it had little vibration and was a bit heavy . I would imagine I don't remember if they came with a "decompression button " . Just alittle chainsaw " reminisce " here on xyz123' s thread .
/ Just another junk chainsaw #1,173
I have never seen or heard of a twin cylinder chainsaw.
I wonder why it never caught on, it looks like she's a runner...
After all back together and pulling over something didnt feel right on 039 and wouldnt start. Backfired once. So starting checking.
They had sheared the key molded into flywheel. Then the fly nut stripped all its thread sand wouldnt come off. Fun fun s o b
I had to cut the freaking nut and use chisel too. Finally off. Some of the crank threads are fubarred too.
I ran a 2 friends twins in solo 100cc 110cc and echo twin.
The echo I pass on around here. Nothing to write home about. Just a heavy 60cc.
Now that solo twin was sweet.
Solo twin
One I ran was 100cc
There is 2 100cc 110cc
/ Just another junk chainsaw #1,177
Pretty cool saws. And both cyl's fire at the same time?
stihl 034 carb that set with ethanol mix drawing in moister in tank.
So I wanted to check this poulan 3700 61cc carb before shipping.
394 372 rings worn next to new.
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2022 Bobcat T770 (A64126)
2022 Bobcat T770...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
(14) 24X48" FLOURESCENT CEILING LIGHTS (A64281)
(14) 24X48"...
