Jumping Glow Plugs
/ Jumping Glow Plugs #1
JoelD
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
Is it possible to jump a glow plug? Can you use jump pack and hook negative to engine block and postive to the glow plug to get them hot?
Thanks,
Joel
/ Jumping Glow Plugs #2
interesting concept- never heard of it being done, but why would you need to do that ? Only thing I seen is youtube showing how to test the glowplugs out of the engine with battery.
/ Jumping Glow Plugs #3
I have "hot wired" glowplugs from a tractor's own battery a few times. In instances of a faulty key switch or similar problem, I can get the tractor running and moved to a more suitable place to do a proper repair. I've been known to run a jumper wire to a fuel shutoff solenoid for similar reasons. Something about working in severe conditions when it's unnecessary becomes less appealing as the years pass.
/ Jumping Glow Plugs #4
You would be better off to use some 10ga wire and a switch that is only on when pushed called a "momentary on".
Chris
/ Jumping Glow Plugs #5
Chris
I don't hardwire them. I disconnect the glowplugs when the heat cycle is complete. A jumper wire with alligator clips is all I use. 'Momentary on' in a different fashion.
1595 (A65054)
1595 (A65054)
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2022 BOBCAT T66 R-SERIES SKID STEER (A65053)
2022 BOBCAT T66...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
