Joystick for JD47 Hoe
   / Joystick for JD47 Hoe #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
I have a JD47 Backhoe Attachment and am wondering if there is a joystick upgrade for the hydraulic controls (2 Levers) or is there an aftermarket upgrade available for this unit ?? Anybody see anything ??? Thanks !!
   / Joystick for JD47 Hoe #2
Wait, does yours NOT have two levers? /forums/images/graemlins/confused.gif
My year old 47 does...
Yes, the hoe controls are 2 levers and I'm wondering if there is a joystick upgrade available thru JD or whoever ?? Seen anything available ???
   / Joystick for JD47 Hoe #4
What would you be expecting a upgrade to do for you? I'm confused as to what the upgrade would entail. In other words, what would you improve with an upgrade?
Cliff
   / Joystick for JD47 Hoe #5
/forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
Cliff...
Sorry, maybe I should have gave more detail; what I'm talking about is a single lever control for the hydraulics on the JD47 Hoe which would be the same or similar to the system used on excavators (large & mini). This would be easier to operate and control the hoe functions because instead of operating 2 separate levers, you would have the one lever or "joystick" like the mini excavators. I've rented a mini excavator before and found the joystick system a dream to operate and was thinking that maybe JD or an aftermarket company might have this system available to change the 2 lever controls to a single multifunction unit. Seen anything ??
Thanks
Eric
   / Joystick for JD47 Hoe #7
This is EASY!! Go use a 4 stick backhoe for a while! Then the 2 stick one will seem so great...
Have you used the 47 much? At first it seemed klutzy. but it quickly got better at interfacing to me... /forums/images/graemlins/wink.gif
Mike....
I've only got 58 hours on the tractor which probably about 10 using the 47 Hoe so I'm far from experienced for sure. Now, a 4 stick would definetly be a challenge. Have you used a joystick setup & what do you think ?? Have you seen anything regarding a retrofit ??
Thanks
Eric
Mike.....
Further to my previous post; maybe I've got a minor problem with my unit because what I'm struggling with is the right control which controls the outboard arm & bucket is nice & smooth, but the left control which controls the inboard arm is "quick" and & I struggle with scooping smoothly toward me because of the difference in control "reaction". If you've got any suggestions I'd appreciate hearing them.
Regards
Eric
   / Joystick for JD47 Hoe #10
Eric,
What RPM is the tractor running at when you are using the backhoe. I have found that running at 1500 to 1800 RPM works best for me. The hoe is not as jerky than when running at higher RPMs.
Chris
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
Caterpillar PS-150C (A50120)
Caterpillar...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
Unused 2025 CFG Industrial QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
