joystick conversion
/ joystick conversion #1
2013 BX2670
/ joystick conversion #2
It probably would, but without specs on it I'd be concerned about it's flow rate capacity.
Can you find any info on it ?
Does one of the circuits have 'float' ?
/ joystick conversion #4
Welcome to TBN:D
Do yourself a favor, get a NEW one with a warranty from a reputable place like the Surplus Center.
Look at these two:
9-7401 ( I think this is the same one on eBay without the rust though...)
9-7694
/ joystick conversion #6
Have you thought of making the bracket to modify the valve you have now? The valves can usually be setup both ways. I would think with a little work you could modify cheaper than buying another valve, of course this depends on the tools you have to work with.
/ joystick conversion #7
I have added two post here, and they disappeared .
WOW, thanks for all the good info. I especially like the idea of modifying what I already have., like AndyF suggested, Can anyone share more of how that is done?
/ joystick conversion #9
One of the guys on here made his own joystick setup. Here are some pictures.
/ joystick conversion #10
/ joystick conversion #11
Heres a joystick I made.
Made it all except for the adjustable length ball/socket rods.
Used nylon bushes in the universal and its still as tight and reliable as when I made it 4 - 5 years ago.
PALLET OF CUT-OFF VALVES (A68842)
PALLET OF CUT-OFF...
PT 1000 Gal Tank (A64912)
PT 1000 Gal Tank...
2007 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2007 INTERNATIONAL...
1992 International 4700 1,200 Gallon Fuel Tanker Truck (A66736)
1992 International...
2009 FORD E250 CARGO VAN (A66091)
2009 FORD E250...
2027 Terext Light Plant (A67714)
2027 Terext Light...
