joystick conversion
/ joystick conversion #1
2013 BX2670
/ joystick conversion #2
It probably would, but without specs on it I'd be concerned about it's flow rate capacity.
Can you find any info on it ?
Does one of the circuits have 'float' ?
/ joystick conversion #4
Welcome to TBN:D
Do yourself a favor, get a NEW one with a warranty from a reputable place like the Surplus Center.
Look at these two:
9-7401 ( I think this is the same one on eBay without the rust though...)
9-7694
/ joystick conversion #6
Have you thought of making the bracket to modify the valve you have now? The valves can usually be setup both ways. I would think with a little work you could modify cheaper than buying another valve, of course this depends on the tools you have to work with.
/ joystick conversion #7
I have added two post here, and they disappeared .
WOW, thanks for all the good info. I especially like the idea of modifying what I already have., like AndyF suggested, Can anyone share more of how that is done?
/ joystick conversion #9
One of the guys on here made his own joystick setup. Here are some pictures.
/ joystick conversion #10
/ joystick conversion #11
Heres a joystick I made.
Made it all except for the adjustable length ball/socket rods.
Used nylon bushes in the universal and its still as tight and reliable as when I made it 4 - 5 years ago.
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
2018 Bomag BC572 Articulated Refuse Compactor (A64553)
2018 Bomag BC572...
Lot 602 (A62613)
Lot 602 (A62613)
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
