joystick conversion
/ joystick conversion #1
2013 BX2670
/ joystick conversion #2
It probably would, but without specs on it I'd be concerned about it's flow rate capacity.
Can you find any info on it ?
Does one of the circuits have 'float' ?
/ joystick conversion #4
Welcome to TBN:D
Do yourself a favor, get a NEW one with a warranty from a reputable place like the Surplus Center.
Look at these two:
9-7401 ( I think this is the same one on eBay without the rust though...)
9-7694
/ joystick conversion #6
Have you thought of making the bracket to modify the valve you have now? The valves can usually be setup both ways. I would think with a little work you could modify cheaper than buying another valve, of course this depends on the tools you have to work with.
/ joystick conversion #7
I have added two post here, and they disappeared .
WOW, thanks for all the good info. I especially like the idea of modifying what I already have., like AndyF suggested, Can anyone share more of how that is done?
/ joystick conversion #9
One of the guys on here made his own joystick setup. Here are some pictures.
/ joystick conversion #10
/ joystick conversion #11
Heres a joystick I made.
Made it all except for the adjustable length ball/socket rods.
Used nylon bushes in the universal and its still as tight and reliable as when I made it 4 - 5 years ago.
