John Deere X304
/ John Deere X304 #1
Ken Hopkins
John Deere X304
Always serviced properly.
4 wheel steering
1177 hours
Threw a belt or broke belt, had it serviced while being repaired. Belt replaced. Used it 2 hours, broke belt again, replaced 2nd belt with instructions to check blade spindles. used it 2 more hours, broke belt again. Independent repair shop. Belts were not OEM John Deere belts.
What is my problem?
/ John Deere X304 #2
Think you answered your question; I've found OEM equipment superior to aftermarket???
/ John Deere X304 #3
You didn't say what belt. Traction belt? Deck belt? 42" decks have had several issues, but it depends on which build you have.
/ John Deere X304 #4
...broke belt again, replaced 2nd belt with instructions to check blade spindles. used it 2 more hours, broke belt again. Independent repair shop. Belts were not OEM John Deere belts.
What is my problem?
Tom - I took the "...instructions to check spindles." to imply he's talking about the mower deck belt.
I agree you that there have been issues with belts on the 42" decks, especially the single belt configuration.
Mostly mis-routing in my experience. Belt guides not installed correctly and worn bearings in idlers and spindles.
Deck cracking and allowing movement of the rear-most central idler under tension is another instance of belt failure.
Patches is correct in his assessment that OEM belts are better than non-OEM on these mowers (IMO)
Ken: did you check (and grease) the spindles ?
Check the idlers for noisy bearings?
Check the belt guides for correct orientation?
/ John Deere X304 #5
What I've found to be the main culprit on many with belt problems is wear in the tensioner arm @ the pivot. The OPs unit could be an earlier build that had old tensioner and guide set up. The ones with the tensioner handle have the guide set up both on the tension arm and behind the large flat idler. These seem to go longer w/o issue. It's the later ones that Deere "improved" that the guides were removed. Many of these have issues 400 hours+, if they didn't have them from new. But they have a bulletin that covers adding the special rear guide and hardware for a ridiculous sum for doing so. FYI, you can get the replacement arms aftermarket and they work just fine.
Notice how the design of the new belts are shaped a bit more like the Accel 42? Enough to where they fit down in the pulley more. A thinner belt is a poor man's way to buy a little more time on these. At least until they snap again.
/ John Deere X304 #6
OEM belts only. And the reason usually is because the OEM ones are very size specific down to the 1/8". Buy OEM ones only.
2019 John Deere M15 Batwing Mower (A66285)
2019 John Deere...
2013 FORD F-250 SUPER DUTY (A65643)
2013 FORD F-250...
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
(4) Yetter Trash Wheels and Cutter (A65640)
(4) Yetter Trash...
