John Deere quick hitch repair
/ John Deere quick hitch repair #1
jb425
sw,va
jd 425
Hello All,
I recently picked up a used JD quick hitch and 54 plow for my 425. The hitch and blade had sat outside for most of its life but it nice and straight with minor surface rust. Got it home and started taking the hitch apart to clean and replace parts as needed. The hoses are dry rotted and the fittings on the cylinders are rusty. I had new hoses made and picked up all brand new fittings while I was at it. My question is when installing the new fittings do I need to apply some kind of sealant to the threads of any or all fittings?
Thanks
/ John Deere quick hitch repair #3
Be very careful to not let any of the tape or sealant get into the lines. Keep it away from the openings.
/ John Deere quick hitch repair #4
Regular "plumbers tape" is NOT recommended for use in hydraulics. Most of the fittings on those lines for the QH are JIC or ORB type IIRC anyway, and do require any type of sealant anyway. Only NPT fittings require it...
/ John Deere quick hitch repair #5
NEVER use tape on hydraulic cpnnections.
ALL your hydraulic connectors will have o-rings, buy new o-rings. Hydraulics never seal with tape, always with o-rings.
/ John Deere quick hitch repair #6
That's only correct if it's a mb (oring) type fitting.
2016 Freightliner M2 106 Ambulance (A64556)
2016 Freightliner...
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
John Deere 3010 Tractor (A66408)
John Deere 3010...
Parker 500 Auger Grain Cart (A66285)
Parker 500 Auger...
Metaltech climb and go (A64553)
Metaltech climb...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
