John Deere keeps blowing starting fuse.
   / John Deere keeps blowing starting fuse. #11
There is a relay under the fusible link I can’t find out what it is for.
This is a good time to obtain electrical schematics or even shop manual for your tractor because this likly will not be the last time you need them. If dealer doesn't have them,they can be downloaded online. Meanwhile maybe someone can tell you where glow plug relay is located. You might try and trace wires back from plugs to see which relay control's them. You should be able to determine if relay is working by watching for amps to fall after a brief period of time.
   / John Deere keeps blowing starting fuse. #13
   / John Deere keeps blowing starting fuse. #14
Follow the wires from the TEMP. Sensor at the neck and unplug it..
I’m going to check it when I get home thank you.
It works thank you all !!!!!!!!
I’ll replace both of the sensors as soon as I can.
   / John Deere keeps blowing starting fuse. #17
Which 2 sensors are you referring to? RE503242 & ?????
   / John Deere keeps blowing starting fuse. #20
Pic #1 is normally the main cause.. I’ve never seen #2 as a problem..
JISAN Heavy Duty Excavator Ripper (New/Unused) to fit CAT320 (A59225)
JISAN Heavy Duty...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
KMC RIPPER SHANK, TIRE & RIM, HAND COME-A-LONG (A52708)
KMC RIPPER SHANK...
JOHN DEERE 630 DISC HARROW (A52708)
JOHN DEERE 630...
250 Traffic Cones (A57453)
250 Traffic Cones...
