John Deere AMT 622 problems
/ John Deere AMT 622 problems #1
Kenjen123
Aiken,sc
John Deere AMT 622 5 wheel
I bought a used John Deere AMT 622 . It idles for a min then stats puttering out. When I drive it I can not go full speed, it dies down to a much slower speed. I though it was perhaps the muffler clogged up but after taking it off it still did the same. I have changed the oil and the spark plug. I am also having a hard time puttin it into forward, lots of grinding. Do I need a clutch. Anythought thanksZ
/ John Deere AMT 622 problems #2
Sounds like a fuel problem. Did it sit for a while? Might be bad gas and varnish in the carb or fuel pump or tank or filter. Start by disconnecting a fuel line and see if you can get good flow. (a filter might be a good idea just on general principals)
/ John Deere AMT 622 problems #3
Sounds like your choke isn't opening up fully or at all.
Hey thanks. I changed fuel filter, changed all oils, new air filters, soaked and cleaned carb, adjusted carb. Worked well up until my kids lost key. I bought new ignition switch and key but it didn't come with a wiring diagram. No clue how to hook up. Any ideas?
/ John Deere AMT 622 problems #5
Ken, shoot me your email, I have a PDF of the tech manual you're welcome to. Wiring drawings are in it too
Joe
/ John Deere AMT 622 problems #6
Joe,
Hopefully you are still on this site. Have an AMT 600 and looking for wiring drawings. If would be greatly appreciated if i could get the PDF.
Thank you,
BRent
/ John Deere AMT 622 problems #7
need your email
Joe
/ John Deere AMT 622 problems #8
Hi Joe! I have a charging problem with my amt 622 do you still have that manual around?
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
