John Deere 790
/ John Deere 790 #1
nck39110
jackson ms
new holland 1715
I have a John Deere 790 tractor and the other day I was bush hogging and the tractor got stuck and I had to pull it out with my truck. Then when I went to load it back on the trailer I noticed the rear wheels had to power and the front wheel was the only one that had power it's like my rear tires won't spin when I put it in gear
/ John Deere 790
Hello, have you tried the differential lock or put it into 2wd?
Yes I have tried the differential lock when I put it in two wheel drive it won't go anywhere in gear
/ John Deere 790 #4
So was it is neutral when you pulled it out? If not, you may have damaged something internal.
/ John Deere 790
Yes it was in neutral when I pulled it out and I had it in 4 wheel drive
/ John Deere 790
Yeah it was in neutral when I pulled it out and now when I put it in 2 wheel drive it won't go anywhere
/ John Deere 790 #7
Well, something in the driveline is obviously, since it was in 4WD while you pulled it, then the 4 wheels (well really 2 or 3) was still linked mechanically. I don't think your going to diagnose this without some disassembly unfortunately. If you've never used JDParts, you might want to get familiar with it now and also get a service manual for the machine.
/ John Deere 790 #8
I suspect it failed prior to this and is why you got stuck. Not familiar with the 790 driveline but hope it is a simple fix for you.
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
2022 EZ-GO ELITE...
150 GALLON FUEL TANKS WITH BRACKETS (A65643)
150 GALLON FUEL...
1999 Coachman Catalina RV/Camper VIN # 3FCMF53S2XJA29020 (A65563)
1999 Coachman...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
2009 Ford F150 (A64194)
2009 Ford F150...
