John Deere 790
/ John Deere 790 #1
nck39110
jackson ms
new holland 1715
I have a John Deere 790 tractor and the other day I was bush hogging and the tractor got stuck and I had to pull it out with my truck. Then when I went to load it back on the trailer I noticed the rear wheels had to power and the front wheel was the only one that had power it's like my rear tires won't spin when I put it in gear
/ John Deere 790
Hello, have you tried the differential lock or put it into 2wd?
Yes I have tried the differential lock when I put it in two wheel drive it won't go anywhere in gear
/ John Deere 790 #4
So was it is neutral when you pulled it out? If not, you may have damaged something internal.
/ John Deere 790
Yes it was in neutral when I pulled it out and I had it in 4 wheel drive
/ John Deere 790
Yeah it was in neutral when I pulled it out and now when I put it in 2 wheel drive it won't go anywhere
/ John Deere 790 #7
Well, something in the driveline is obviously, since it was in 4WD while you pulled it, then the 4 wheels (well really 2 or 3) was still linked mechanically. I don't think your going to diagnose this without some disassembly unfortunately. If you've never used JDParts, you might want to get familiar with it now and also get a service manual for the machine.
/ John Deere 790 #8
I suspect it failed prior to this and is why you got stuck. Not familiar with the 790 driveline but hope it is a simple fix for you.
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
3pt 55 Gal Rear End Boom Sprayer (A64127)
3pt 55 Gal Rear...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
John Deere Sign (A64127)
John Deere Sign...
