John Deere 790
/ John Deere 790 #1
nck39110
jackson ms
new holland 1715
I have a John Deere 790 tractor and the other day I was bush hogging and the tractor got stuck and I had to pull it out with my truck. Then when I went to load it back on the trailer I noticed the rear wheels had to power and the front wheel was the only one that had power it's like my rear tires won't spin when I put it in gear
/ John Deere 790
Hello, have you tried the differential lock or put it into 2wd?
Yes I have tried the differential lock when I put it in two wheel drive it won't go anywhere in gear
/ John Deere 790 #4
So was it is neutral when you pulled it out? If not, you may have damaged something internal.
/ John Deere 790
Yes it was in neutral when I pulled it out and I had it in 4 wheel drive
/ John Deere 790
Yeah it was in neutral when I pulled it out and now when I put it in 2 wheel drive it won't go anywhere
/ John Deere 790 #7
Well, something in the driveline is obviously, since it was in 4WD while you pulled it, then the 4 wheels (well really 2 or 3) was still linked mechanically. I don't think your going to diagnose this without some disassembly unfortunately. If you've never used JDParts, you might want to get familiar with it now and also get a service manual for the machine.
/ John Deere 790 #8
I suspect it failed prior to this and is why you got stuck. Not familiar with the 790 driveline but hope it is a simple fix for you.
2016 Kubota RTV X1140 (A65579)
2016 Kubota RTV...
2013 JCB 506-36 TELESCOPIC FORLKLIFT (A65053)
2013 JCB 506-36...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
