john deere 755
/ john deere 755 #1
robbridgland
Bucknell UK
John Deere 755
Hi
I need an owners manual for 755
I have technical manual but what I need is simple owners manual
Any ideas where I can download one
Rob
/ john deere 755 #2
You can buy one at your John Deere Dealer for the 755 European Version, Part Number OMM95305
/ john deere 755 #3
Hi
Rob
I have the manual for the 655/755/855/955 on my computer send a pm with your e mail address and I should be able to send it to you 037.jpg
/ john deere 755 #5
I got a tractor with house I bought its a 755 john deere. bought the manual to find out what all the levers etc do. It came with a 60"blower and was wondering if thats to big?? I then looked at rear pro lever rabbit-neutral-turtle! The pto doesn't turn when in rabbit for the snow blower?? only turtle and N which I believe is only to be used when you have a backhoe attachment?? Any body out there know?? Shouldn't there be 2 speeds for the blower??
/ john deere 755 #6
Welcome to TBN!
That lever you are describing controls the two speed ranges of the tranaxle, not the PTO. Theres a lever on the left side which controls whether the PTO that operates is the mid- PTO, the rear PTO, or both. Since you describe a 60" blower, I assume you are describing a 3 pt hitch rear blower. Yes, 60" is a bit large for a 755, but it all depends on how many inches of snow, how wet it is, and how fast you want to travel while blowing.
/ john deere 755 #7
I have a 855 and the pto only spins at 540 rpm and engine speed has to be above I believe 2000 rpm for it to engage .No 2 speeds for the blower only the transaxle
/ john deere 755 #8
Not exactly correct... there is only one gear for the PTO, but PTO speed is dependent upon engine speed. I believe the engine speed is 3200 RPM in order to get 540 RPM at the rear PTO. Also, the mid PTO is either 1000 or 2000 RPM (can't remember which) at the rated engine speed.
/ john deere 755
Hi
Sorry to keep bothering you but have troubles with my 755.
My mechanic needs owners manual, says parts manual has too much info.
If you do have copy on your computer it would help greatly if you could send me down load
e mail is robbridgland@gmail.com
Again sorry to be a pest but you are my best chance
Best regards
Rob
PS if you are Scotch Whiskey drinker I will bring a nice bottle next time I come to States. Usually over 6 times a year
/ john deere 755 #10
Hi
Best regards
Rob
I have been trying to send it but the cd has some kind of closed system for anti download from the seller .
/ john deere 755 #11
Correct if you have a true Deere cd manual it is a protected file and you will have difficulty emailing it. You can however copy and past the pertinat (sp?) info and place that into email. Robbridgeland what kind of info are you trying to find out?
/ john deere 755
Hi
Thanks for answer. That figures
Any chance you could print it and scan and send it
If its not too much of a pain and not too many pages.
Its really oil levels the mechanic is interested in.
Routine stuff about what lever does what we already figured out plus we don't use mower.
Tyre pressures would help
If you can do that I will send you two bottles of the finest whiskey
You are only good contact I have on this
Best regards
Rob
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
2015 Chevrolet Silverado Pickup Truck (A62613)
2015 Chevrolet...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59914)
2023 KENWORTH T680...
2005 TerraGator 8104 (A63688)
2005 TerraGator...
John Deere 4040 Tractor (A64047)
John Deere 4040...
100 Gal Oil Container (A64127)
100 Gal Oil...
