John Deere 650 Maintenance
/ John Deere 650 Maintenance #1
captainabe
Ohio
John Deere 650 4x4
Alright all you experienced tractor owners. I need some direction on what I should do to my JD 650 to prepare it for winter storage (when the time comes) /forums/images/graemlins/cool.gif. Any and all guidance will be appreciated since I am new to tractors.
/ John Deere 650 Maintenance #2
I run my tractor in the winter, so it's a bit different for me. I'd be sure the fuel tank was full to prevent condensation, and add some additive like Power Service to deal with water and algae. You might want to then drain the fuel in the spring and refill it. On a gasoline engine, it's often recommended to run the engine out of fuel to eliminate gumming problems, but I don't think I'd do that with a diesel.
Plan on putting the charger to the battery in spring.
Be sure all the fluids are up and grease it.
I suppose keeping it in a heated shed is too much to expect. Still, storing it indoors may decrease the problem with critters turning it into a winter home. Otherwise, put some rat poison bait stations under it.
The easiset solution may be to go out every month and run it to exercise the engine, but with my luck, the tractor would be stored three states away.
Thanks for the suggestions!
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2022 PETERBILT 579 6X4 T/A CAB AND CHASSIS (A69167)
2022 PETERBILT 579...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2023 WEILER K560 KNUCKLEBOOM LOADER (A65056)
2023 WEILER K560...
