John Deere 650 Clutch replacement
/ John Deere 650 Clutch replacement #1
Wreckaboy1
Merrimack NH
John Deere 650
Hi
I have a mid 80's John deere 650 , 4wd tractor with bucket loader. I'm in the process of replacing the clutch. I've got a copy of the service manual and have followed the instructions for splitting the tractor. I can only get the tractor spread apart about an inch. I have everything disconnected, and the drive shat is not seized on the slip joint for the splined shaft. Does anyone have any recommendations? I have the front supported via an engine hoise and a floor jack for the rear.
Thanks
Joe
603-365-5219
/ John Deere 650 Clutch replacement #2
You might have a "bind" in the shafts. It may be a little too high or too low. You need to play with the hoist and floor jack to try and eliminate any bind. Raise or lower a little and try to get it to split more.
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
WORKSAVER 3PT / LOADER BALE SPEAR MOUNT (A64278)
WORKSAVER 3PT /...
PALLET OF LOAD JACKS W/ CASTER WHEELS (A64278)
PALLET OF LOAD...
Toro ProLine 37in Walk Behind Commercial Mower (A64194)
Toro ProLine 37in...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
