John Deere 6405 won't move and pto does not work
   / John Deere 6405 won't move and pto does not work #1
RyanMire
Scott,la
John Deere 6400,6405,6215,6230,2355,1020
I was bush-hogging and the hydraulic return line that goes to the filter blew off. I repaired it and added oil back to the tractor, now it will not move nor will the pto work. The 3 point, hydrolic remotes and steering all work at this time. Any ideas??
   / John Deere 6405 won't move and pto does not work #2
Welcome to the forum. :welcome:
I'm going to move your thread over to the John Deere section to see if we can find you some answers.
   / John Deere 6405 won't move and pto does not work #3
Also, welcome to TBN
How much oil did you have to add? And what oil did you add? We'll try to help you out..
I added 7 gallons of the premium hydraulic oil from tractor supply.
   / John Deere 6405 won't move and pto does not work #5
:welcome: to TBN
Sounds as if you might have an electrical problem. Have you checked wiring & fuses?
   / John Deere 6405 won't move and pto does not work #6
I doubt the oil is the problem, but I do not think TSC oil meets JD's specs (HyGard specs)
:welcome: to TBN
I was thinking the same thing, if a hose pulled off, maybe wires or a connector pulled apart.
I was thinking the same thing, if a hose pulled off, maybe wires or a connector pulled apart.[/
I check ,no wire came unconnected or fuse blown.
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A51572)
2019 Ford F-550...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2014 Doyle Dry...
