John Deere 6405 won't move and pto does not work
   / John Deere 6405 won't move and pto does not work #1
RyanMire
Scott,la
John Deere 6400,6405,6215,6230,2355,1020
I was bush-hogging and the hydraulic return line that goes to the filter blew off. I repaired it and added oil back to the tractor, now it will not move nor will the pto work. The 3 point, hydrolic remotes and steering all work at this time. Any ideas??
   / John Deere 6405 won't move and pto does not work #2
Welcome to the forum. :welcome:
I'm going to move your thread over to the John Deere section to see if we can find you some answers.
   / John Deere 6405 won't move and pto does not work #3
Also, welcome to TBN
How much oil did you have to add? And what oil did you add? We'll try to help you out..
I added 7 gallons of the premium hydraulic oil from tractor supply.
   / John Deere 6405 won't move and pto does not work #5
:welcome: to TBN
Sounds as if you might have an electrical problem. Have you checked wiring & fuses?
   / John Deere 6405 won't move and pto does not work #6
I doubt the oil is the problem, but I do not think TSC oil meets JD's specs (HyGard specs)
:welcome: to TBN
I was thinking the same thing, if a hose pulled off, maybe wires or a connector pulled apart.
I was thinking the same thing, if a hose pulled off, maybe wires or a connector pulled apart.[/
I check ,no wire came unconnected or fuse blown.
bad boy zero turn 72 (A56859)
bad boy zero turn...
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2018 Ford F-150 4X4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
Hays LT-1 Tender (A56435)
Hays LT-1 Tender...
PARKER P-5 VICE (A58374)
PARKER P-5 VICE...
