John Deere 6405 won't move and pto does not work
   / John Deere 6405 won't move and pto does not work #1
RyanMire
Scott,la
John Deere 6400,6405,6215,6230,2355,1020
I was bush-hogging and the hydraulic return line that goes to the filter blew off. I repaired it and added oil back to the tractor, now it will not move nor will the pto work. The 3 point, hydrolic remotes and steering all work at this time. Any ideas??
   / John Deere 6405 won't move and pto does not work #2
Welcome to the forum. :welcome:
I'm going to move your thread over to the John Deere section to see if we can find you some answers.
   / John Deere 6405 won't move and pto does not work #3
Also, welcome to TBN
How much oil did you have to add? And what oil did you add? We'll try to help you out..
I added 7 gallons of the premium hydraulic oil from tractor supply.
   / John Deere 6405 won't move and pto does not work #5
:welcome: to TBN
Sounds as if you might have an electrical problem. Have you checked wiring & fuses?
   / John Deere 6405 won't move and pto does not work #6
I doubt the oil is the problem, but I do not think TSC oil meets JD's specs (HyGard specs)
:welcome: to TBN
I was thinking the same thing, if a hose pulled off, maybe wires or a connector pulled apart.
I was thinking the same thing, if a hose pulled off, maybe wires or a connector pulled apart.[/
I check ,no wire came unconnected or fuse blown.
2010 Freightliner M2 106 T/A Altec D2050A BR Digger Derrick Truck (A55973)
2010 Freightliner...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2019 GALYEAN...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
2018 ISUZU NPR 16FT BOX TRUCK (A58017)
2018 ISUZU NPR...
