John Deere 6405 won't move and pto does not work
   / John Deere 6405 won't move and pto does not work #1
RyanMire
Scott,la
John Deere 6400,6405,6215,6230,2355,1020
I was bush-hogging and the hydraulic return line that goes to the filter blew off. I repaired it and added oil back to the tractor, now it will not move nor will the pto work. The 3 point, hydrolic remotes and steering all work at this time. Any ideas??
   / John Deere 6405 won't move and pto does not work #2
Welcome to the forum. :welcome:
I'm going to move your thread over to the John Deere section to see if we can find you some answers.
   / John Deere 6405 won't move and pto does not work #3
Also, welcome to TBN
How much oil did you have to add? And what oil did you add? We'll try to help you out..
I added 7 gallons of the premium hydraulic oil from tractor supply.
   / John Deere 6405 won't move and pto does not work #5
:welcome: to TBN
Sounds as if you might have an electrical problem. Have you checked wiring & fuses?
   / John Deere 6405 won't move and pto does not work #6
I doubt the oil is the problem, but I do not think TSC oil meets JD's specs (HyGard specs)
:welcome: to TBN
I was thinking the same thing, if a hose pulled off, maybe wires or a connector pulled apart.
I was thinking the same thing, if a hose pulled off, maybe wires or a connector pulled apart.[/
I check ,no wire came unconnected or fuse blown.
PALLET BOX OF MISC (A58374)
PALLET BOX OF MISC...
Case Titan 3530 (A56435)
Case Titan 3530...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
