John Deere 4600 starter
/ John Deere 4600 starter #1
ab1953
PA
john deer b john deere 4600 international 300
When I try to start my John Deere 4600 sometimes it will turn over as it should and sometimes it will spin without engaging the flywheel. It grinds on the flywheel. I am wondering if it could be the thermistor or some other problem.
/ John Deere 4600 starter #2
My guess would be a sticking starter drive or a worn spot on the flywheel ring gear. Either way you would want to remove the starter to inspect. If it is a sticky starter drive and you keep allowing it to grind it WILL become a ring gear issue.
Thank you for your reply. You were absolutely right. I took the starter apart and sprayed it with a spray lubricant and it is working fine now. I don't know how long it will last but at least now I know that the problem is the starter.
Thanks again.
/ John Deere 4600 starter #4
My 4600 had an issue like this a few years ago. When you kicked on the starter, sometimes it would just create a nasty grinding sound, other times it would engage and start up. A friend recommended that I remove the starter, and engage it while not installed in the tractor. Put on a leather glove and press on the starter gear while engaging. He said that if the starter solenoid is bad, then it will be fairly easy to keep the gear from extending. A good starter would be hard to oppose. Turns out it was easy to hold it back. A new starter was found on ebay for around $100. With the new starter, this have never happened again.
Thanks for your reply on my starter issue. I found that my starter drive needed lubricating but I will try to remember what you said about how to check it out next time.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2011 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65053)
2011 GENIE Z-45/25...
2017 MAC Half Round T/A End Dump Trailer (A64194)
2017 MAC Half...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A65053)
2021 CATERPILLAR...
Year: 2023 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 44,433 (A64557)
Year: 2023 Make...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
