Oil & Fuel john deere 445 no power to injector
   / john deere 445 no power to injector #1
billeads1975
hillsboro ohio
john deere 445
hello, i have a john deere 445 and i am not getting power to my fuel injector, have started checking fuses and connections but no good luck, any ideas?
   / john deere 445 no power to injector #2
What else works/doesn't work?
Battery Load Tested?
Starter motor cranks??
Lights?
PTO Clutch clicks when ignition 'On'?
You have a Module, Manifold Pressure sensor, Air Temp sensor, and another sensor (Air flow?) from memory.
Much to go wrong...
   / john deere 445 no power to injector #3
Nothing electrical on the injectors.. IF your talking about the electric shut off solenoid on the injection PUMP.. just remove it to SEE if that's your problem.. if it is, the tractor will start..
   / john deere 445 no power to injector #4
Hope billeads comes back for a look.
Agree on the single injector.. shows electrical connect. Also found a fuel injector test.
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2022 CATERPILLAR 302.7 CR EXCAVATOR (A52707)
2022 CATERPILLAR...
2011 VOLVO A40E OFF ROAD DUMP TRUCK (A52707)
2011 VOLVO A40E...
2023 CATERPILLAR 420 BACKHOE (A52707)
2023 CATERPILLAR...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Nissan CF60 6,000lb LP Forklift (A55851)
Nissan CF60...
