Oil & Fuel john deere 445 no power to injector
   / john deere 445 no power to injector #1
billeads1975
hillsboro ohio
john deere 445
hello, i have a john deere 445 and i am not getting power to my fuel injector, have started checking fuses and connections but no good luck, any ideas?
   / john deere 445 no power to injector #2
What else works/doesn't work?
Battery Load Tested?
Starter motor cranks??
Lights?
PTO Clutch clicks when ignition 'On'?
You have a Module, Manifold Pressure sensor, Air Temp sensor, and another sensor (Air flow?) from memory.
Much to go wrong...
   / john deere 445 no power to injector #3
Nothing electrical on the injectors.. IF your talking about the electric shut off solenoid on the injection PUMP.. just remove it to SEE if that's your problem.. if it is, the tractor will start..
   / john deere 445 no power to injector #4
Hope billeads comes back for a look.
Agree on the single injector.. shows electrical connect. Also found a fuel injector test.
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2022 BOBCAT MT100 STAND-ON SKID STEER (A60429)
2022 BOBCAT MT100...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
