Oil & Fuel john deere 445 no power to injector
   / john deere 445 no power to injector #1
billeads1975
hillsboro ohio
john deere 445
hello, i have a john deere 445 and i am not getting power to my fuel injector, have started checking fuses and connections but no good luck, any ideas?
   / john deere 445 no power to injector #2
What else works/doesn't work?
Battery Load Tested?
Starter motor cranks??
Lights?
PTO Clutch clicks when ignition 'On'?
You have a Module, Manifold Pressure sensor, Air Temp sensor, and another sensor (Air flow?) from memory.
Much to go wrong...
   / john deere 445 no power to injector #3
Nothing electrical on the injectors.. IF your talking about the electric shut off solenoid on the injection PUMP.. just remove it to SEE if that's your problem.. if it is, the tractor will start..
   / john deere 445 no power to injector #4
Hope billeads comes back for a look.
Agree on the single injector.. shows electrical connect. Also found a fuel injector test.
2017 Ford F-750 Super Duty (A53317)
2017 Ford F-750...
UNUSED FUTURE FT13 EXCAVATOR (A57192)
UNUSED FUTURE FT13...
UNUSED FUTURE 10' GALVALUME CORRUGATED SIDING (A57193)
UNUSED FUTURE 10'...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
UNUSED FUTURE SZYMJ HYD STUMP GRINDER (A57193)
UNUSED FUTURE...
2018 Ford Transit 150 Cargo Van (A55852)
2018 Ford Transit...
