Oil & Fuel john deere 445 no power to injector
   / john deere 445 no power to injector #1
billeads1975
hillsboro ohio
john deere 445
hello, i have a john deere 445 and i am not getting power to my fuel injector, have started checking fuses and connections but no good luck, any ideas?
   / john deere 445 no power to injector #2
What else works/doesn't work?
Battery Load Tested?
Starter motor cranks??
Lights?
PTO Clutch clicks when ignition 'On'?
You have a Module, Manifold Pressure sensor, Air Temp sensor, and another sensor (Air flow?) from memory.
Much to go wrong...
   / john deere 445 no power to injector #3
Nothing electrical on the injectors.. IF your talking about the electric shut off solenoid on the injection PUMP.. just remove it to SEE if that's your problem.. if it is, the tractor will start..
   / john deere 445 no power to injector #4
Hope billeads comes back for a look.
Agree on the single injector.. shows electrical connect. Also found a fuel injector test.
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
2019 KUBOTA SVL75-2 SKID STEER (A52707)
2019 KUBOTA...
1980 Gleaner F2 with heads (A55315)
1980 Gleaner F2...
UNUSED FUTURE HYD MINI HEDGE CUTTER (A57193)
UNUSED FUTURE HYD...
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
