JOHN DEERE 4430 LOAD CONTROL SHAFT
/ JOHN DEERE 4430 LOAD CONTROL SHAFT #1
cdupuy
Waco, TX
MF 135, John Deere 4430
Hello all, i have a JD 4430 that is leaking hydraulic fluid around the load control shaft. I removed the load control shaft, pictures attached. I am guessing that i need to buy a new shaft because of the ridges on the old shaft. The ridges are not deep, but may be enough to cause a leak. I am thinking that i will just replace the seals # 18, and #19 and not replacing the bushing #20. the bushing looks tight in the transmission housing. I really don't want to try to drive out bushing #20. what do you think?
also, is it critical to replace the #15 bushing, and #16 snap ring on the yoke #9? there is quite a lot of play between the load shaft/pin and the bearing in the yoke.
thanks for the help. Carr
/ JOHN DEERE 4430 LOAD CONTROL SHAFT #2
Welcome to TBN
I agree shaft appears worn enough to require replacement. I was taught when i served as a JD dealer service manager to replace L/D shaft bushings only if showing some significant wear. Do you pull heavy 3 pt hitch loads? If not I personally would not replace frt bushing/pin(items 10 & 11).
My JD 4255 that I purchased used in Feb '93 when it was 1.5 yrs old has original frt bushing & pin. I've replaced L/D seals twice & my 4255 with 11,600+ hrs has pulled it's share of heavy loads(6X14 moldboard & 24 ft integral field cultivator) plus pulling rd baler to bale over 125000 rd bales
thanks TX Jim. what does L/D shaft/bushings mean? i am not that good at acronyms.
i do not pull heavy 3 pt loads, mostly pull heavy drawbar loads- 11 ft. disc, 15 ft shredder. This may not be considered heavy loads.
I am ok with not replacing items 10 & 11. what about items 15 & 16 on the same drawing?
thank you!
/ JOHN DEERE 4430 LOAD CONTROL SHAFT #4
L/D=load & depth. L/D bushinngs are item 20 in the 1st parts diagram you posted. Item 15 & 16 are bushing & bushing retaining snap ring that is located in drawbar support that load & depth shaft fit in. I don't remember ever seeing enough wear to replace them but check for excessive wear before reassembly
Thanks tx Jim, I appreciate your willingness to share your expertise.
/ JOHN DEERE 4430 LOAD CONTROL SHAFT #6
You're welcome. Answering questions about tractor & equipment problems helps keep my aging brain functioning(y)
/ JOHN DEERE 4430 LOAD CONTROL SHAFT #7
I agree with TxJim, do not to replace the bushings (key 20) in the transmission case. R&R of these bushings can cause the transmission case to be damaged = more expensive problem.
I received my load shaft, load shaft seals, and o-rings. i heated the shaft seals in hot water before I installed the seals. heating the seals made installation fairly easy. with the load shaft oiled, the installation of the shaft was easy too. thanks for all the help.
/ JOHN DEERE 4430 LOAD CONTROL SHAFT #9
Congratulations on your successful repair & thank you for update
Jim
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
2017 Ford F-550 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
