John Deere 4300 SCV Question
/ John Deere 4300 SCV Question #1
sloch24
Oak Harbor, OH
John Deere 4300
I have a JD4300 with a 430 FEL. I am unable to simultaneously lift and tilt the bucket.
The loader feels strong otherwise. It will lift fully, tilt fully, and has power to lift the front of the tractor off of the ground. I am just unable to tilt while lifting.
I'm assuming this is not normal?
I just got the tractor a couple of weeks ago with about 1100 hours, so I did a full fluid and filter change, but I read somewhere about a small filter that can be cleaned if performance degrades. I thought that pertained to the 3-point, but I'm not sure. Does the SCV have any kind of filter in it?
I'm new to tractors, and this site, so any info is appreciated.
Thanks for all of the replies. I did find that if I move the controls slower that it works correctly. Maybe it's a volume issue (not enough volume to do both at the same time at higher speeds).
Anyway, it works. I'll just have to get used to running the controls at less than full speed.. :)
/ John Deere 4300 SCV Question #3
I have a 4410 and it takes precise movements to control both functions at the same time.
2017 Mack Semi (A64047)
2017 Mack Semi...
GRACO KING XL45 PROTECTIVE COATING SPRAYER (A67714)
GRACO KING XL45...
2437 (A65640)
2437 (A65640)
7002SFL (A61572)
7002SFL (A61572)
TWO CHAINSAWS (A67714)
2007 Mack CHN613 T/A Day Cab Truck Tractor (A66736)
2007 Mack CHN613...
