Prmc
I have a 1999 model 4300 john Deere compact utility tractor with a 430 front end loader. It has 500+ hours on it. The hydraulic fluid and filter has been changed twice since new. There is a slow leak down on the front arms and bucket, even when the engine is operating. In addition the 3 point arms leak down, but raise again while the tractor is running. When the engine is off, both ends of the tractor leak down. This is not a new occurance, has been doing it for awhile, but is picking up the pace to the point of being a nuisance. Do I have a check valve leaking that's common to both hydraulic areas? I would appreciate some help on this from someone with far more experience than I. Sometime before I noticed this problem, I also bought a 485 backhoe for this unit and had the JD dealer install it. They put a skid plate on and "power Beyond" to have the flow the BH needed. Everything functioned well after that, but as I say, the problem is getting worse now. I am Thanking everyone in advance for your ideas and thoughts!
