John Deere 410C QUESTIONS!!!
   / John Deere 410C QUESTIONS!!!
Re: John Deere 410C QUESTIONS!!! * Updated w/ Pics
Welded on a 32" Thumb.
Used my Trusty 1710 to carefully get the new boom, and Dipper Pinned on.
My house project got delayed as did this. But now I'm almost there. Tree work on my property is done with about 2 1/2 acres clear cut. Just finishing up this Hoe so I can get out there and rip my stumps out..
Also added a new toy to the stable!
   / John Deere 410C QUESTIONS!!! #15
Now that is wore out!
   / John Deere 410C QUESTIONS!!! #16
UPDATE!!!! With Pics! Here is the Frame to upper swing tower mount after I got it all apart. Talk about ugly!View attachment 325566
Fwiw and consideration for next time in similar applications. there is Chockfast Orange. It could have saved you a lot of time amd sweat. Simply mix and pour in-situ. This is used in ships rudder post bearings that take a worse beating than any excavator or backhoe could ever imagine.
ITW Chockfast Marine | Epoxy Grouts, Adhesives, Repair Products, Coatings
Interesting thought... Have you ever used it? Luckily I was able to find a local parts machine that was in reasonable condition, and cut off that mount from the parts machine, and the mount from my machine and welded on the new one. That's what I love about forums, its the cross technical knowledge. Some stuff works, and some doesn't BUT thats all worthwhile knowledge.
   / John Deere 410C QUESTIONS!!! #18
Redundant post.
   / John Deere 410C QUESTIONS!!! #19
That has to be the worst bearing mount I have ever seen that remained intact. Yes, I have used Chockfast in the same and similar applications, plus chocking heavy marine diesels, reduction gears, shaft bearing mounts, and skeg rudder bearings. It is far cheaper and faster than milling steel shim parts, and withstands enormous forces and vibrations. There are also several brands on the market that would also be suitable such as Devcon | acrylic, acrylic adhesive, adhesive, adhesive and sealants, adhesive applicator
One of Chockfast's claims to fame was that it was used extensively in the re-powering of the QE2: The Repowering Of QE2
All back together and working nicely! A little slop, but definitly homeowner worthy. The swing to boom pins still need to be replaced, that should tighten it up a bit.
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
3ft Teakwood Totem Pole (A57454)
3ft Teakwood Totem...
CATERPILLAR D3 CRAWLER DOZER (A60429)
CATERPILLAR D3...
Forklift (A59228)
Forklift (A59228)
Tractor Tires and Rims (A56860)
Tractor Tires and...
